Home > Technical > Battery Drainage Unfixable at Land Rover |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 |
worth a try mate as you know 1 problem with these cars can throw up other problems which might not be the cause |
Wed Mar 20 2013 1:07pm |
It sounds like your car isn't "going to sleep"
if it was me i would tell them to open the switch up if its corroded inside then replace the switch with all what you have done to the car id stick with it i was the same as you i nearly give up on the car and felt like taking a hammer to it but then i found the problem and touch wood nothing since |
Wed Mar 20 2013 1:36pm |
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 |
Land Rover have called and advised they have now changed the upper tailgate switch, the Sat NAv itself, The bluetooth phone, the module under the seat, the dvd player and also a new Amplifier.
Mon Mar 25 2013 3:10pm |
Insist they give you the old parts back. They can't all be broken; put the good ones up for sale on this website 2008 MY Java Black TDV8 HSE |
Mon Mar 25 2013 3:22pm |
Tue Mar 26 2013 11:05am |
Guess what????? |
Wed Mar 27 2013 12:30pm |
errrr... it's all fixed and you're a happy bunny? 2008 MY Java Black TDV8 HSE |
Wed Mar 27 2013 12:56pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 |
It wont start? SVR 2018 in Santorini Black. |
Wed Mar 27 2013 6:42pm |
It didn't start this morning !!!!!
Wed Mar 27 2013 9:36pm |
i take it they did replace the uppertailgate switch id check if i was you |
Wed Mar 27 2013 9:43pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4405 |
It's a sad state of affairs when a main dealer can't fix a car
Thu Mar 28 2013 6:57am |
They advised the rear upper tailgate switch was fine and didnt require replacing.
Mon Apr 01 2013 9:52pm |
Meccles Member Since: 06 Aug 2011 Location: QLD Posts: 152 |
Mmm sounds all too familar. I have pm'd you again. No resolution in sight on mine either. It failed again yesterday.
Tue Apr 02 2013 1:58pm |
