![]() | Home > Technical > Battery Drainage Unfixable at Land Rover |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
worth a try mate as you know 1 problem with these cars can throw up other problems which might not be the cause |
It sounds like your car isn't "going to sleep"
if it was me i would tell them to open the switch up if its corroded inside then replace the switch with all what you have done to the car id stick with it i was the same as you i nearly give up on the car and felt like taking a hammer to it but then i found the problem and touch wood nothing since |
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 ![]() ![]() ![]() |
Land Rover have called and advised they have now changed the upper tailgate switch, the Sat NAv itself, The bluetooth phone, the module under the seat, the dvd player and also a new Amplifier.
Guess what????? |
errrr... it's all fixed and you're a happy bunny? 2008 MY Java Black TDV8 HSE ![]() |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
It wont start? SVR 2018 in Santorini Black. |
It didn't start this morning !!!!!
i take it they did replace the uppertailgate switch id check if i was you |
It's a sad state of affairs when a main dealer can't fix a car |
They advised the rear upper tailgate switch was fine and didnt require replacing.
Meccles Member Since: 06 Aug 2011 Location: QLD Posts: 152 ![]() ![]() ![]() |
Mmm sounds all too familar. I have pm'd you again. No resolution in sight on mine either. It failed again yesterday.
