Home > Technical > Battery Drainage Unfixable at Land Rover
Page 1 of 3 123>
Harry HST
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
Hi Guys
Need your help with what you think the outcome will be on my RRS.
I purchased a 2005 RRS from Land Rover last year and the car came with a 6 months warranty.
Since I had purchased the vehicle I have had nothing but problems with battery drainage and faults.
The car has undertaken modifications and a colour change to the Autobiography style since purchase.
All the issues have been raised the Land Rover and they have had the vehicle in about 8 times now in a space of 4 months and they cannot find the fault even though they are aware that there is a fault there.
The dealer principal has advised that they have tried everything they can but the fault appears to remain and they cant figure it out.
They are now going to speak with the Dealer Principals to see what outcome is going to suit all parties.
Does anyone have any idea of what the outcome could be?
Post #377566 Wed Mar 20 2013 9:53am
Confused
Possible swap like for like?... but don't count on something with an A/B kit on it.
I'd make noises you want the kit transfered and colour matched. RRS gone
Post #377567 Wed Mar 20 2013 9:55am
Disco_Mikey
I have seen instrument packs cause battery drains. Normally cured by a software update Thumbs Up
This may not be the same issue as yours, but worth a check.
Also, seen loose battery terminals cause drain issues, but I would imagine they have already been checked
Post #377568 Wed Mar 20 2013 9:56am
Harry HST
Hi
They have replaced the battery all terminals are fine, they have done a software update and a hard reset.
What appears to happen from time to time is that the sat nav screen and the radio freezes which causes the battery to drain when the car is locked.
Either the Radio LCD/Sat NAV Screen remain on which causes the battery to drain.
The dealer had told me they found the problem a month back advising that the complete radio was locking itself out and causing it to freeze so they replaced the whole stereo unit and said its working fine now.
3 dqays later same again started the car in the morning and the sat nav screen and radio froze no sound or anything then when parked and locked they wouldn't turn off!
Really bizarre that they cant find the fault but I've spent like £10k doing the coversion and colour change so really dont know what the outcome will be, the car is still under warranty so dont know the position I'm in due to this fault not being able to be repaired.
Post #377571 Wed Mar 20 2013 10:08am
Bradders
Maybe try another dealer. If it's under LR warranty it should be fixed period. FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
EX 2007 FL2 XS - not so bad
Post #377579 Wed Mar 20 2013 10:56am
Harry HST
They've advised it would be my local dealer only who will be dealing with this as the vehicle has been into them many times already.
I dont know whether there was a re call on the l322's at any stage but they simply haven't got a clue.
Post #377580 Wed Mar 20 2013 11:02am
Bradders
I'm not so sure they can dictate which dealer you take the RRS to. The point being your local one has failed to sort the car out so you must be entitled to take it elsewhere or hand it back after you've agreed what to do about the kit etc.
Mrs Bradders would have the Dealer Principal in tears by now.....I just leave her to it. is there a Mrs Harry HST who can kick off Thumbs Up FF 4.4 V8 Soooo looking forward to this bad boy
Post #377581 Wed Mar 20 2013 11:11am
Yup, time to unleash the big guns.... Rolling with laughter In times like this I set Mrs Bean on them.....never fails Whistle Rolling with laughter ON THE WAY: BMW F21 M140i
Post #377586 Wed Mar 20 2013 11:47am
JPR 1
I agree, this dealer had had many attempts to fix the car. I have had this issue in the past with a dealer.
I insisted I wanted a second opinion and have another dealer took at look at it.
I also informed them to go on this forum as they might get an idea of how to fix a car they built Very Happy
In the end the second dealer found the fault within two days, they even gave me a courtesy car free of charge.
Good luck with this and keep us informed Thumbs Up
Post #377588 Wed Mar 20 2013 11:59am
Harry HST
Mrs HST will not get involved in my politics with dealers!! ( She's a BMW Lover Shocked )
Here is the reply I have had from Land Rover:
Morning **** / ******,
Just had a discussion with Mr ***** ref his ongoing issue with his battery drain on his RRS.
Obviously Mr ***** is frustrated with the fact the same problem keeps re-occurring, and the fault doesn’t seem to be rectified, and of course it’s the same for us with regard to the frustration of not being able to rectify or find the source of the drain.
I have asked Mr ***** what his thoughts are in relation to coming out of the RRS, if his confidence has depleted in this particular vehicle, but as he has explained, he has spent £****** upgrading the vehicle to his desired specification since the purchase.
Is it possible we could raise this fault with Land Rover and explain the situation?, maybe you already have?, I am just trying to find the fastest outcome possible for Mr ***** to conclude the matter?
Regards,
Post #377590 Wed Mar 20 2013 12:12pm
baxc
have you tried the upper tailgate switch thats what was causing mine to drain
Post #377591 Wed Mar 20 2013 12:44pm
Paddi
Unbelievable that a main dealer can't find an electrical fault and just wants to give up! Really?.
Surely you'd expect that any self-respecting organisation as a matter of principle would be determined to track down the source. Perhaps they might have to send it to a vehicle electrical specialist as part of their obligations to you the owner; have they offered to do that?
I wonder if they have checked the infamous corroding switch on the tailgate glass? Rolling with laughter 2008 MY Java Black TDV8 HSE
Post #377592 Wed Mar 20 2013 12:46pm
Harry HST
I've not tried or messed with anything in all fairness.
As it's udner warranty i've left it to the dealers to sort so to be honest I dnt know whether they have checked the upper tailgate switch i'm assuming they would of if its a common problem.
Harry
Post #377593 Wed Mar 20 2013 12:46pm
baxc
i wouldnt trust the dealers to know this as when i had my battery drain it took me 3 weeks of testing to find it i phoned loads of dealers and they all said they have never had a battery drain i think i was 1 of the first on this forum to have this problem and since i posted many have had this same problem for the sake of £30 i would change the switch Thumbs Up
Post #377598 Wed Mar 20 2013 12:56pm
Harry HST
Sounds like a plan but as mentioned the drain is coming from the Sat Nav/Radio it freezes and doesnt turn off which is causing the drain.
I doubt its the tailgate switch which is having intermitance with the stereo, it appears an electrical fault along the lines somewhere.
Post #377599 Wed Mar 20 2013 1:03pm
Page 1 of 3 123>
