Home > Technical > left blender motor replace
Page 1 of 3 123>
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Just got my car back from a 134.000 service. Found out that the left blender motor is broken and thats why its only coming warm air out from just one vent:(
Anyone know if its an expensive job? RRS 2006 2.7 HSE
Post #353078 Tue Aug 07 2012 1:45pm
mse
Re: left blender motor replace
Edited for accuracy Mr. Green
Anyone know how expensive the job will be?
 Mike
2014 Facelift Discovery
Post #353087 Tue Aug 07 2012 3:54pm
firstinretail
United Kingdom 2005 Range Rover Sport 4.4 V8 Siberian Silver
blend motor is about £20 getting to the Censored is another thing, from what i gather its not an expensive job, around 1 hr. If you took some fog and put it in a jar, would it be missed.
Post #353169 Wed Aug 08 2012 1:17pm
RRSNorway
Anyone done this job before? My dealer said it would take about 6 hours to change the left blendermoter......hm..... Yawn £800 for the job here in Norway... RRS 2006 2.7 HSE
Post #356372 Thu Sep 13 2012 7:56am
firstinretail
What, I recon you could do an engine in 6hrs..... I am going to do mine this weekend fingers crossed, so will let you know. If you took some fog and put it in a jar, would it be missed.
Post #356439 Thu Sep 13 2012 6:33pm
RRSNorway
I'm on yor side;) 6 hours is way to long. If anyone can confirm how log it takes I can take this to my dealer. RRS 2006 2.7 HSE
Post #356442 Thu Sep 13 2012 6:51pm
mse
If you can ill be really impressed...even more if you get it in (assuming body is staying on) Mike
Post #356458 Thu Sep 13 2012 8:23pm
RRSNorway
Could you have a chat with your dealer for me about how long it should take? I 'm planing to do the blender job asap:) RRS 2006 2.7 HSE
Post #356468 Thu Sep 13 2012 8:57pm
Bobby
If this is what you're talking about...
...how long do you think it will take?? Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #356487 Thu Sep 13 2012 11:46pm
RRSNorway
Shocked Should take 30 min if this is the right job. I'v got the partnumber: LR JWO500030.
Is this the same part/job? If so I'm going to have a chat with my dealer Wink RRS 2006 2.7 HSE
Post #356491 Fri Sep 14 2012 6:59am
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
The left hand side (passenger side in the UK) requires the glove box to be removed and the workshops manual says a special tool is required to remove the hinge pins for the glove box.
Does anyone know if there's a trick to doing it without the special tool ?
"Roads ? Where we're going there are no roads." Back to the future.
Post #356499 Fri Sep 14 2012 8:20am
With my technical skills, that'd be a 6 hour job Wink Rolling with laughter ON THE WAY: BMW F21 M140i
Post #356500 Fri Sep 14 2012 8:22am
RRSNorway
I hear you! Im going down to the garage to have a lock, but I don't get the pics you posted? Instrument panel driver side?? Is that under/on side/ over the steering wheel? RRS 2006 2.7 HSE
Post #356503 Fri Sep 14 2012 9:04am
mrfrog
That's the vertical panel that goes down to the footwell and all the way back to the armrest.
To get it out, you need to remove the sat nav surround, central console (Gear level knob, Park brake and terrain control assembly, fridge/box and the top of the central console), you'll need to remove the trim near the steering wheel (square-ish block), the length of trim that runs alongside the panel you eventually want to remove (sort of runs along your leg when you sit in the car), then you should be able to finally remove the instrument reinforcement panel.
It mostly unclips from the body of the car, there may be 6 or 8 screws to remove in total.
Look for my post on DIY installation in maintenance and modifications and you'll get an idea of what you need to remove, although I've not gone as far as you'll need to.
Post #356505 Fri Sep 14 2012 9:09am
RRSNorway
Damn!
Purhaps this is why my dealer said 6 hours Rolling Eyes
So the blender is located at my left leg, but I need to remove all the bits on my right leg side...
So this is the only way to get to the left blender on a LHD.
A bit to much work for me in the garage i think....hehe RRS 2006 2.7 HSE
Post #356510 Fri Sep 14 2012 9:32am
Page 1 of 3 123>
