Home > Technical > What's that sounds?
rm0rgan
What's that sounds?
When I switch my RRS's engine off, I can hear something still whining under the bonnet - it's not the wife, so just wondered what it could be?
Thanks Very Happy Wife's Car: BLACK RRS TDV8 HSE with all the bits Smile
My Car: Lotus Exige S2 PP & TP Smile)
Post #308660 Thu Aug 04 2011 10:41pm
0cj0
is it like a quiet whining/clicking noise?
Post #308662 Thu Aug 04 2011 11:05pm
rm0rgan
Yes - more whining than clicking - also does it if I switch the ignition on and then off again even without starting the car. Is it some sort of priming pump? Wife's Car: BLACK RRS TDV8 HSE with all the bits Smile
Post #308667 Fri Aug 05 2011 8:28am
tluk
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
I've had a v8 for 3 weeks now and have noticed the same sound, with the bonnet up it appears to be coming from the upper central area of the inlet area, sounds a little like a high voltage line whistling.
I would be interested in the answer to this issue.
Post #308731 Fri Aug 05 2011 7:29pm
The Kergan
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Nara Bronze
I can faintly hear the DVD running for the sat nav running under the passenger seat. Do you think it could be that as it becomes active as soon as the car is opened and whirls away after the engine is switched off. 2017 Range Rover Sport Autobiography
Post #308732 Fri Aug 05 2011 7:33pm
Siberianfox
England 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
could it be the compressor? Smile
Post #308734 Fri Aug 05 2011 8:11pm
tluk
The compressor for the suspension is mounted nearside rear wheel area not under the bonnet, or it is on mine.
Post #308740 Fri Aug 05 2011 8:59pm
Siberianfox
It was just just a thought Thumbs Up Smile
Post #308743 Fri Aug 05 2011 9:08pm
jed.w
rm,
You're on an RRS forum, we all hear the whining constantly!
Twisted Evil SDV6 HSE Sport2 - Santorini Black, Ebony Interior, Pano Roof, Things I haven't found yet!
TDV6 HSE, Java Black, Black Premium Leather, Privacy, LR Side Steps, Smoked Side Repeaters, SC Vents and lots of toys!
Post #308746 Fri Aug 05 2011 9:13pm
Viscus fan Question Question
Post #308748 Fri Aug 05 2011 9:14pm
tluk
The noise can be heard even when the engine has not been started. If I turn the ignition and and don't start up when I turn off and get out the noise is there.
Post #308755 Fri Aug 05 2011 10:03pm
Fuel been pumped to the engine Thumbs Up
Post #308757 Fri Aug 05 2011 10:17pm
simon1233
+1 Thumbs Up Also you will hear the other systems priming themselves, boosting coolant through the AC etc
Post #308761 Fri Aug 05 2011 11:54pm
mse
There are a few, one i want to know is the buzzer like sound until you lock after you shut down.
I know inside you can hear the infotainment system, outside the compressor can be heard when the engine is off Mike
2014 Facelift Discovery
Post #308774 Sat Aug 06 2011 9:35am
rm0rgan
Yes - this would make sense. Glad it's not just mine!!
Thanks for the info and thoughts Thumbs Up Wife's Car: BLACK RRS TDV8 HSE with all the bits Smile
Post #308833 Sat Aug 06 2011 9:45pm
