![]() | Home > Technical > What's that sounds? |
0cj0 Member Since: 23 Sep 2010 Location: York Posts: 290 ![]() ![]() |
is it like a quiet whining/clicking noise? |
rm0rgan Member Since: 04 Jun 2011 Location: Ross on Wye Posts: 42 ![]() ![]() ![]() |
Yes - more whining than clicking - also does it if I switch the ignition on and then off again even without starting the car. Is it some sort of priming pump? Wife's Car: BLACK RRS TDV8 HSE with all the bits ![]() My Car: Lotus Exige S2 PP & TP ![]() |
tluk Member Since: 21 Jul 2011 Location: Oldham Posts: 17 ![]() ![]() ![]() |
I've had a v8 for 3 weeks now and have noticed the same sound, with the bonnet up it appears to be coming from the upper central area of the inlet area, sounds a little like a high voltage line whistling.
The Kergan Member Since: 14 May 2011 Location: Wiltshire Posts: 294 ![]() ![]() ![]() |
I can faintly hear the DVD running for the sat nav running under the passenger seat. Do you think it could be that as it becomes active as soon as the car is opened and whirls away after the engine is switched off. 2017 Range Rover Sport Autobiography |
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 ![]() ![]() ![]() |
could it be the compressor? |
The compressor for the suspension is mounted nearside rear wheel area not under the bonnet, or it is on mine. |
It was just just a thought |
jed.w Member Since: 02 Jan 2011 Location: West Lancashire Posts: 191 ![]() ![]() |
rm,
Viscus fan |
The noise can be heard even when the engine has not been started. If I turn the ignition and and don't start up when I turn off and get out the noise is there. |
Fuel been pumped to the engine |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 ![]() ![]() |
+1 ![]() |
There are a few, one i want to know is the buzzer like sound until you lock after you shut down.
Yes - this would make sense. Glad it's not just mine!! Thanks for the info and thoughts ![]() ![]() My Car: Lotus Exige S2 PP & TP ![]() |
