Home > Technical > What's that sounds? |
0cj0 Member Since: 23 Sep 2010 Location: York Posts: 290 |
is it like a quiet whining/clicking noise? |
Thu Aug 04 2011 11:05pm |
rm0rgan Member Since: 04 Jun 2011 Location: Ross on Wye Posts: 42 |
Yes - more whining than clicking - also does it if I switch the ignition on and then off again even without starting the car. Is it some sort of priming pump? Wife's Car: BLACK RRS TDV8 HSE with all the bits My Car: Lotus Exige S2 PP & TP ) |
Fri Aug 05 2011 8:28am |
tluk Member Since: 21 Jul 2011 Location: Oldham Posts: 17 |
I've had a v8 for 3 weeks now and have noticed the same sound, with the bonnet up it appears to be coming from the upper central area of the inlet area, sounds a little like a high voltage line whistling.
Fri Aug 05 2011 7:29pm |
The Kergan Member Since: 14 May 2011 Location: Wiltshire Posts: 294 |
I can faintly hear the DVD running for the sat nav running under the passenger seat. Do you think it could be that as it becomes active as soon as the car is opened and whirls away after the engine is switched off. 2017 Range Rover Sport Autobiography |
Fri Aug 05 2011 7:33pm |
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 |
could it be the compressor? |
Fri Aug 05 2011 8:11pm |
The compressor for the suspension is mounted nearside rear wheel area not under the bonnet, or it is on mine. |
Fri Aug 05 2011 8:59pm |
It was just just a thought |
Fri Aug 05 2011 9:08pm |
jed.w Member Since: 02 Jan 2011 Location: West Lancashire Posts: 191 |
rm,
Fri Aug 05 2011 9:13pm |
Viscus fan |
Fri Aug 05 2011 9:14pm |
The noise can be heard even when the engine has not been started. If I turn the ignition and and don't start up when I turn off and get out the noise is there. |
Fri Aug 05 2011 10:03pm |
Fuel been pumped to the engine |
Fri Aug 05 2011 10:17pm |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 |
+1 Also you will hear the other systems priming themselves, boosting coolant through the AC etc |
Fri Aug 05 2011 11:54pm |
There are a few, one i want to know is the buzzer like sound until you lock after you shut down.
Sat Aug 06 2011 9:35am |
Yes - this would make sense. Glad it's not just mine!! Thanks for the info and thoughts Wife's Car: BLACK RRS TDV8 HSE with all the bits My Car: Lotus Exige S2 PP & TP ) |
Sat Aug 06 2011 9:45pm |
