![]() | Home > Maintenance & Modifications > Tools to Replace front brake pads? |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
I'm thinking of replacing my front brake pads myself as I recall it being said it is very easy.
http://www.rrsport.co.uk/gallery/albums/us...Brakes.pdf Malaysia Boleh!
Thanks Bobby! |
I think the idea of having the jar is because you have to press the pistons into the caliper housing which will push the brake oil. You could forgo this route by opening the brake fluid reservoir and allowing the excess fluid to flow out.
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Depends if your brake fluid has been filled during the course of the wear, i opened the lid placed a rag around the opening and kept an eye on the level whilst depressing the cylinders....
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 ![]() ![]() ![]() |
The reservoir should cope with normal pad wear, if it has been topped up during normal wear then it may overflow when new pads are fitted. Good reason NOT to top up during normal use unless the level goes too low as per the manual in which case seek the leak! Cheers
Exactly |
Thanks for all this..
I recall this less clearly but seem to think front was easy rear more difficult as the connector was less accessible. Do not recall removing liner though..... I am having some recollection of undoing clips but realising afterwards i didn't need to.
EASY??! |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
2nd
I have the free servicing, unfortunately doesn't stretch to brake's... I had some time to kill so thought I'd give it a go... The pads were a sinch.. the sensor is a b |
If i get time tomorrow i'll have a look remind myself and assist further if able - i don't recall it being a problem - certainly fronts were easy IIRC...
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 ![]() ![]() |
Bobby is there a PDF for the Brembo front brake swap?
