Home > Maintenance & Modifications > Tools to Replace front brake pads? |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
I'm thinking of replacing my front brake pads myself as I recall it being said it is very easy.
Mon May 25 2009 10:28pm |
http://www.rrsport.co.uk/gallery/albums/us...Brakes.pdf Malaysia Boleh!
Mon May 25 2009 11:45pm |
Thanks Bobby!
Tue May 26 2009 5:55am |
I think the idea of having the jar is because you have to press the pistons into the caliper housing which will push the brake oil. You could forgo this route by opening the brake fluid reservoir and allowing the excess fluid to flow out.
Tue May 26 2009 6:45am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Depends if your brake fluid has been filled during the course of the wear, i opened the lid placed a rag around the opening and kept an eye on the level whilst depressing the cylinders....
Tue May 26 2009 7:27am |
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 |
The reservoir should cope with normal pad wear, if it has been topped up during normal wear then it may overflow when new pads are fitted. Good reason NOT to top up during normal use unless the level goes too low as per the manual in which case seek the leak! Cheers
Tue May 26 2009 11:34am |
Exactly |
Tue May 26 2009 11:52am |
Thanks for all this..
Thu May 28 2009 5:35am |
I recall this less clearly but seem to think front was easy rear more difficult as the connector was less accessible. Do not recall removing liner though..... I am having some recollection of undoing clips but realising afterwards i didn't need to.
Thu May 28 2009 6:33am |
EASY??!
Thu May 28 2009 7:23am |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 |
2nd
Thu May 28 2009 8:07am |
I have the free servicing, unfortunately doesn't stretch to brake's... I had some time to kill so thought I'd give it a go... The pads were a sinch.. the sensor is a b tard and I'd like to see pictures of how to replace it easily as it's seems impossible!
Thu May 28 2009 8:39am |
If i get time tomorrow i'll have a look remind myself and assist further if able - i don't recall it being a problem - certainly fronts were easy IIRC...
Thu May 28 2009 6:09pm |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 |
Bobby is there a PDF for the Brembo front brake swap?
Wed Dec 02 2009 4:00pm |
