Home > Maintenance & Modifications > Tools to Replace front brake pads?
Bobby
dazsear wrote:
Bobby is there a PDF for the Brembo front brake swap?
Daz
You mean this?
Hope its the same for your later model! Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #244229 Wed Dec 02 2009 9:28pm
dazsear
Thanks Bobby
Looks very simple, just waiting for my pads and sensor wire to arrive in the post.
Daz 2017 4.4 Autobiography FFRR - love this car
Gone - VW T5 Transporter
Long gone - 2009 Disco
Long gone but never out of my thoughts - 2008 TDV8 HST
Post #244323 Thu Dec 03 2009 7:35pm
tornado34
2006 Range Rover Sport TDV6 HSE Zambezi Silver
Sorry Bobby, any chance of a rear change pdf too (non Brembo)?
If the wear indicator light hasn't triggered, is it possible to re-use the sensor, making it even easier by not having to trace back to the sensor connector?
Post #252393 Thu Jan 28 2010 5:30pm
MAW
Yes on the sensor issue - if it hasn't worn through you can re use - ie you can use it if worn but to a certain amount Thumbs Up
Post #252400 Thu Jan 28 2010 6:04pm
tornado34
Cheers MAW, slowly getting my parts and knowledge sorted for the DIY service - Confused
Post #252408 Thu Jan 28 2010 6:25pm
tornado34
MAW you must be the brake expert, or certainly lead poster!!!!
Trawling through past posts for rear pad change help and you're everywhere - you must change your brakes more often than I change my underwear Laughing
Great info though and now I'm going to attempt myself - what's the worst that can happen....uuurrrgh crash, death, no afterlife???? Maybe take another view when I start to dismantle Confused
Post #252424 Thu Jan 28 2010 8:01pm
Bobby
Rear Brake Pads Malaysia Boleh!
Post #252437 Thu Jan 28 2010 9:48pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Not entirley certain but is there not some procedure involved on the rear set up with the EPB mechanism and making sure it is re-adjusted Question
Post #252438 Thu Jan 28 2010 9:54pm
Bobby
No, I don't think so. The EPB components are in the drum and you're not going there just to change the disc pads.
A word of caution, though..
Quote:
WARNING: Prior to removing a brake disc from a vehicle, power should be disconnected from the parking brake module.
Operation of the parking brake switch while a brake disc is removed can cause the actuating mechanism in the parking brake module to seize.
In addition, the parking brake may not switch off until 20 minutes after key-off; automatic re-apply cannot be eliminated until this period has expired.
 Malaysia Boleh!
Post #252439 Thu Jan 28 2010 10:04pm
