Home > Maintenance & Modifications > Tools to Replace front brake pads?
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
I'm thinking of replacing my front brake pads myself as I recall it being said it is very easy.
The key questions is do I need any specific tools that I may not ordinarily have in my basic tool box?
TIA
Post #226631 Mon May 25 2009 11:28pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Bobby Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #226633 Mon May 25 2009 11:32pm
Bobby
http://www.rrsport.co.uk/gallery/albums/us...Brakes.pdf Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #226639 Tue May 26 2009 12:45am
2nd Rower
Thanks Bobby! Bow down Bow down Bow down
Can anyoe who has done this comment on the need for the bleed jar - That doesn't make sense to me as I won't be touching the fluid or pipes?
Post #226646 Tue May 26 2009 6:55am
Bobby
I think the idea of having the jar is because you have to press the pistons into the caliper housing which will push the brake oil. You could forgo this route by opening the brake fluid reservoir and allowing the excess fluid to flow out.
That's the only reason I can think of! Smile Malaysia Boleh!
Post #226650 Tue May 26 2009 7:45am
MAW
Depends if your brake fluid has been filled during the course of the wear, i opened the lid placed a rag around the opening and kept an eye on the level whilst depressing the cylinders....
My levels were fine and did not expel any surplus...
Post #226651 Tue May 26 2009 8:27am
simonsi
United Kingdom 2007 Range Rover Sport TDV6 HSE Arctic Frost
The reservoir should cope with normal pad wear, if it has been topped up during normal wear then it may overflow when new pads are fitted. Good reason NOT to top up during normal use unless the level goes too low as per the manual in which case seek the leak! Cheers
Simon
2007 2.7HSE 20" Wheels
2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails
Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo
Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer
Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes
Post #226687 Tue May 26 2009 12:34pm
MAW
Exactly Thumbs Up
Post #226698 Tue May 26 2009 12:52pm
2nd Rower
Thanks for all this..
Have changed the pads easily.
Also have to change the sensor and having trouble repalcing this. I can't seem to be able to do it without pulling the wheel arch lining out? Is this correct, and if so how do I do that as the rubber stops don't seem to want to move. I'm hesitatnt to use to much brute force in case I break something..?
TIA again.
Post #226880 Thu May 28 2009 6:35am
MAW
I recall this less clearly but seem to think front was easy rear more difficult as the connector was less accessible. Do not recall removing liner though..... I am having some recollection of undoing clips but realising afterwards i didn't need to.
The clips I did undo the centre pulled out a few mm allowing the clip to relax and pull out..... IIRC i offered the new cable next to the old to see where the connector was as it wasn't that clear...
Hope this is of some use Confused
If you don't sort it post a pic and it may jog the grey matter a little more .... Laughing
Post #226883 Thu May 28 2009 7:33am
2nd Rower
EASY??! Shocked
I cannot see how you can get your fingers in there without removing some of the clips.
I now have two undone and am still sruggling to get enough access to apply leverage to disconnect the original sensor cable.
For a wear and tear part this is a ridiculous design IMO land Rover... Evil or Very Mad
Looks like I'll have to get more cli[ps out or give up and drive to the stealer tomorrow!
Post #226887 Thu May 28 2009 8:23am
BKHK
2nd
Its all that off roading you have been doing. If your liners were amoral'd like mine, I am sure it would be much easier Rolling with laughter
I will leave all of that to the dealer....I have just confirmed that my new car also has the free 3 year servicing plan so no greasy fingers for me. Laughing Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #226890 Thu May 28 2009 9:07am
2nd Rower
I have the free servicing, unfortunately doesn't stretch to brake's... I had some time to kill so thought I'd give it a go... The pads were a sinch.. the sensor is a b Censored tard and I'd like to see pictures of how to replace it easily as it's seems impossible!
Dealer seems to have given me an incompatible sensor cable too.. Now that I can see it having flexed the liner all the way back!
Post #226893 Thu May 28 2009 9:39am
MAW
If i get time tomorrow i'll have a look remind myself and assist further if able - i don't recall it being a problem - certainly fronts were easy IIRC...
Rear i think it was a case of sliding underneath and tracing the cable back to the connector
Post #226948 Thu May 28 2009 7:09pm
dazsear
Bobby is there a PDF for the Brembo front brake swap?
Daz 2017 4.4 Autobiography FFRR - love this car
Gone - VW T5 Transporter
Long gone - 2009 Disco
Long gone but never out of my thoughts - 2008 TDV8 HST
Post #244209 Wed Dec 02 2009 5:00pm
