![]() | Home > Technical > RRS TDV6 2.7 ISSUES |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
Try searching the codes on here or on www.Disco3.co.uk
Hoverdroid Member Since: 17 Mar 2024 Location: Swindon Posts: 36 ![]() ![]() ![]() |
Thanks for your reply Andy.
gearbox oil. You want something ZF6HP26 compatible
UPDATE
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9045 ![]() ![]() ![]() |
The gearbox fault could be linked to the engine issue. I read somewhere on here (a while ago so it's hazy) that the gearbox goes in to a limp home mode if there's a serious engine issue in order to protect itself and the engine. Hopefully with the engine side sorted, a code clear will sort it.
So the leaking injectors i sorted, the cylinder balance issue on number 3 pot i am estimating it could be a faulty injector. (P0269-00)
Try a fuel filter to see if it fixes the pressure fault code. |
Okey dokie, i'll change the fuel filter |
Haven't located the fuel filter so far, Wondering if this model actually has one externally. (The mind boggles).
I'd start by downloading the workshop manual from here: https://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf
Fuel filter under the car.
U codes are communication problems between modules. Most of the time you can ignore them unless you have serious issues.
Hi Andy, This new diagnostic unit was only giving me said codes (unlike the earlier unit). The Mucar unit didnt have the ability to do any resets so was no good. This new unit has the ability to do all resets. I did manage to reset the EPB system and the transmission adaptation relearn.
Located the fuel filter hidden behind a panel by fuel tank. It looks to be a screw on canister type.
