Home > Technical > RRS TDV6 2.7 ISSUES |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4975 |
Try searching the codes on here or on www.Disco3.co.uk
Mon Sep 30 2024 11:40am |
Hoverdroid Member Since: 17 Mar 2024 Location: Swindon Posts: 35 |
Thanks for your reply Andy.
Mon Sep 30 2024 12:23pm |
gearbox oil. You want something ZF6HP26 compatible
Mon Sep 30 2024 12:42pm |
UPDATE
Tue Oct 22 2024 1:51pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8998 |
The gearbox fault could be linked to the engine issue. I read somewhere on here (a while ago so it's hazy) that the gearbox goes in to a limp home mode if there's a serious engine issue in order to protect itself and the engine. Hopefully with the engine side sorted, a code clear will sort it.
Tue Oct 22 2024 4:03pm |
So the leaking injectors i sorted, the cylinder balance issue on number 3 pot i am estimating it could be a faulty injector. (P0269-00)
Tue Oct 22 2024 5:24pm |
Try a fuel filter to see if it fixes the pressure fault code. |
Tue Oct 22 2024 5:48pm |
Okey dokie, i'll change the fuel filter |
Tue Oct 22 2024 6:06pm |
Haven't located the fuel filter so far, Wondering if this model actually has one externally. (The mind boggles).
Tue Oct 29 2024 4:17pm |
I'd start by downloading the workshop manual from here: https://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf
Tue Oct 29 2024 5:18pm |
Fuel filter under the car.
Tue Oct 29 2024 6:08pm |
U codes are communication problems between modules. Most of the time you can ignore them unless you have serious issues.
Tue Oct 29 2024 6:41pm |
Hi Andy, This new diagnostic unit was only giving me said codes (unlike the earlier unit). The Mucar unit didnt have the ability to do any resets so was no good. This new unit has the ability to do all resets. I did manage to reset the EPB system and the transmission adaptation relearn.
Tue Oct 29 2024 8:12pm |
Located the fuel filter hidden behind a panel by fuel tank. It looks to be a screw on canister type.
Wed Oct 30 2024 4:08pm |
