Home > Technical > RRS TDV6 2.7 ISSUES
Page 4 of 4 <1234
Hoverdroid
I'll check tommoz Andy. Smile
I'm trying to research the U0416 code as that pops up twice in the system.
Apparently..... the injectors on this model dont need coding in? (Found that strange) but the destruction manual says they dont.
Post #645131 Thu Nov 07 2024 1:01pm
Hoverdroid
Anyone have any ideas how to secure the plastic bush that controls the steering angle sensor. No-one i've talked too seem none the wiser.
At first i thought it was the angle sensor but ruled that out when i saw the bush turning on its own, seems the keyways are worn.
Post #647188 Thu Mar 06 2025 2:46pm
James s m
Scotland
Yeah my steering angle sensor did this like 5 years ago , one day it just stopped working which I could see on my iid tool so I bought another one spent ages fitting it them put it all back together and still exactly the same , them looked at it again and seen the plastic bush just at fault , so them spoke to a Land Rover specialist and they said eather get a new bush and take most of the sterling shaft out to change it or just take the angle sensor out the way then cover the plastic in super glue to make it spin with the shaft again
5 years later and the glue is still holding fine , worth a try ?
Hope this helps 2017-Discovery 5 TDV6 HSE
2007-Range Rover sport “ endless money pit “
2005-Discovery 3
Post #647199 Fri Mar 07 2025 10:39pm
Page 4 of 4 <1234
