Home > Technical > RRS TDV6 2.7 ISSUES
Page 3 of 4 <1234>
Hoverdroid
Hi Billy
I'm based in North Swindon , Wiltshire sn25
Post #645010 Thu Oct 31 2024 8:08pm
Hoverdroid
I'd happily pay for someone to reprogramme gearbox for me.
Post #645012 Thu Oct 31 2024 8:10pm
Billy82
Shame im in Manchester
Post #645013 Thu Oct 31 2024 8:12pm
Hoverdroid
Thanks for the consideration bud anyway Thumbs Up
Post #645014 Thu Oct 31 2024 8:14pm
Hoverdroid
UPDATE
Today was interesting, the fuel filter is now changed, the old one was all rusty at top, Primed up and engine started.
So i thought i'd read the dtc's again to see if that had cleared any of the PCM codes, well nope it didn't.
As a passing thought i investigated the injectors these are the values i was getting:
Cylinder balancing offsets:
#1 - 700
#2 - 600
#3 - 600
#4 - 600
#5 - 645
#6 - 1400
When i rev engine to approx 1100rpm all values go to 1000.015
Here is the codes on the PCM side of things (Current)
1. P1335 - 21
2. P0191 - 24
3. P0191 - 65
4. P0269 CYL 3 contribution
5. 0x000 watchdog reset ?????? no idea what this gremlin is
6. P140E (sensor c)
When i try to move vehicle back and forth it really struggles to move
The EGR system i have blanked but not deleted from software.
Post #645020 Fri Nov 01 2024 1:02pm
It's probably using 3rd gear, which is one reason why it doesn't want to move.
Looking at those injector offsets, one seams very high. 6
Trouble is, injector and cylinder numbers are different!
Probably cylinder 3 injector needs changing as that is the one will the ballance code. Think that is the drivers RHD, rear.
Of course with fuel pressure error codes anything could be happening.
I guess I worry that you have fitted a Euro 3 engine to a Euro 4 car or other way round.
Maybe some pics of the top of the engine may inspire some thoughts from people.
You don't have any of the old parts from the old engine do you? What was wrong with the old engine and gearbox?
Post #645021 Fri Nov 01 2024 2:09pm
Hoverdroid
Afternoon Andy.
I dont have the old engine nor gearbox, they been scrapped buddy.
The engines were identical in comparison and both stated 276DT on the rocker.
The rear fuel belt didnt need timing. Unlike the other models and the HPFP is the one from the original engine with the injectors.
The only thing different on this engine is that i've blanked the egr's.
Post #645022 Fri Nov 01 2024 2:28pm
Hoverdroid
The old engine oil pump failure the common snap off issue, which caused catastrophic damage to engine, bits everywhere, which also resulted in smashing the starter motor which then smashed the gearbox bell housing.
Post #645023 Fri Nov 01 2024 2:31pm
Hoverdroid
Here’s some pic’s ( if i got that right ) lol
in the gallery section (couldn't work out how to put them here in this box Laughing
Obviously these pic's are the new replacement lump (not the old engine), i will look to see if i got pic of old lump
Post #645024 Fri Nov 01 2024 2:35pm
Hoverdroid
Here is the old engine (hopefully)
Post #645025 Fri Nov 01 2024 2:48pm
Post #645026 Fri Nov 01 2024 3:16pm
Hoverdroid
Thanks Andy Smile
Post #645027 Fri Nov 01 2024 3:37pm
Hoverdroid
UPDATE
Probed the injectors today
Inj 1 - 199.6
Inj 2 - 199.6
Inj 3 - 200.3
Inj 4 - 199.7
Inj 5 - 199.9
Inj 6 - 199.3
I checked also if any of the solenoids were going to ground all passed.
I still changed Injector 3 (To see if it would cure the contribution/balance issue)
I'm waiting on a replacement fuel rail pressure sensor then i'll fire it up and see what happens.
Post #645099 Mon Nov 04 2024 5:57pm
Hoverdroid
UPDATE:
Changed the injector on cyl 3, changed the Fuel rail sensor, charged the battery.
Started car today and i was shocked.... It actually ran and revved. No 'F' in display, moved car about the yard and driving ok backwards and forwards. Bit smokey thou LOL
So cleared codes and rediagnosed
P1335 (Egr)
P0269 (Cyl 3 contribution/balance)
P140E (Egr)
U0159 (Park assist issue, rear right inner and outer sensor)
U0416 (this code pops up in two systems including the TCM)
Post #645129 Thu Nov 07 2024 11:51am
well that's is good news! (for the gearbox) Must have been the fuel pressure sensor.
What are the injector offsets now?
Post #645130 Thu Nov 07 2024 12:25pm
Page 3 of 4 <1234>
