Home > Technical > RRS TDV6 2.7 ISSUES
Page 1 of 4 1234>
Hoverdroid
RRS TDV6 2.7 ISSUES
Hi everyone i need some help ( owning a RRS i think i do) lol
Ok, i have a few dtc codes come up after fitting a replacement engine and gearbox (Ebay Specials)
I finally managed to get the air out of the fuel system and got the thing started and idling. Warmed it up a bit and thought i'd check codes as its running lumpy and although no mil lamp illuminated it wont rev past 2500 (maybe a limp mode) but no lamp on?
Ok codes are:
PO191 - 24 (fuel pressure sensor range)
PO191 - 65 (fuel pressure sensor range)
PO625 - 11 ( Generator field circuit low)
PO269 - 00 ( Cyl 3 Contribution/balance)
U2023 - 86 (Fault received ....) TCM
I can see cyl 5 & 6 injectors are wet indicating a leak (or seating issue)
There is also a HDC fault (no code)
Transmission stating 'F' on dash clock info display
Now do i set fire to it or can anyone save my sanity on this Bow down
I really love this truck and i'd love to keep it.
I really appreciate any help and time you afford me
Thank you Smile
Post #644486 Mon Sep 30 2024 11:08am
Try searching the codes on here or on www.Disco3.co.uk
Check fuel pressure sensor plugged in, or try sensor off old engine
Generator field circuit low - This means the alternator light is on basically. Check alternator plug and 5A ALT fuse in battery fusebox
( Cyl 3 Contribution/balance) - It's having problems doing the fuel trims. Maybe because of the pressure issue. or maybe a belt valve in heads
Sometimes the gearbox ecu (megatronics unit) is VIN coded. That maybe the cause of the last fault code. Read gearbox codes. You may need to swap the megatronics, (or reprogram with GAP IID) but sort the engine out first.
Post #644488 Mon Sep 30 2024 12:40pm
Hoverdroid
Thanks for your reply Andy.
In regards to fuel pressure yes i'll investigate to see why the injectors are wet/leaking and see if that has an effect on codes.
As for the Alternator light goes off when engine running, any ideas? I'll check the multiplug for connections.
As for gearbox, i'm going to do a sump conversion to metal, whilst there i'm going to change the mechatronic electrical sleeve and of course new filter. Although i see so many variations on transmission oil, man i'm confused lol.
Is there anyone who can code it in once i have changed sump ? i dont have the Gap system, i only have a Launch code reader and Tech 2 for the GM.
Post #644489 Mon Sep 30 2024 1:23pm
gearbox oil. You want something ZF6HP26 compatible
e.g https://www.ebay.co.uk/itm/280911012341?_s...R8Dalq_IZA
I would sort out the electric issue first, else you will only end up draining the oil again.
Read gearbox codes if you can
If the alternator is working, try clearing the code or ignoring!
Post #644491 Mon Sep 30 2024 1:42pm
Hoverdroid
UPDATE
Injector 5 & 6 were leaking at unions, slight tweak and they are now ok.
Is there anyone nr or in Swindon that could do a gearbox reset for me? I bought something i was told would do it and na, junk. Mucar BT200. (going in bin).
Bow down
Post #644840 Tue Oct 22 2024 2:51pm
The gearbox fault could be linked to the engine issue. I read somewhere on here (a while ago so it's hazy) that the gearbox goes in to a limp home mode if there's a serious engine issue in order to protect itself and the engine. Hopefully with the engine side sorted, a code clear will sort it.
I haven't used them, but there is Ridgeway 4x4 https://www.ridgeway4x4.co.uk/ who claim to be LR specialists. I'd have thought they could clear codes for you for a nominal fee. 2012 SDV6 - it's missing a couple of cylinders
Post #644841 Tue Oct 22 2024 5:03pm
Hoverdroid
So the leaking injectors i sorted, the cylinder balance issue on number 3 pot i am estimating it could be a faulty injector. (P0269-00)
(P0191-24) Fuel rail pressure range/performance ( i'm hoping changing the cyl 3 injector may cure this (i hope).
(P01335-21) EGR position sensor min stop performance ( ive blanked the egr's just havent got software to delete)
(U2023 -86) Fault received from external node ( Transmission) ( its a gearbox from another doner car so i'm hoping resetting it will cure it (fingers crossed) when i can get someone to do it...lol
(U0100-87) Lost communication with ecm / pcm 'A' ( This is on the PBM system, not sure what the fault is directly.... however, the emergency brake release had been pulled to move vehicle onto trailer at some point. I dont know if its possible to electronically reset this or do i have to open up the module and reconnect manually? )
Here's a new one ... (U0401 - 6Cool Invalid data received from ecm/pcm in the VDM system
I did send Richard at Ridgeway 4 x 4 an email last week, no reply as yet.
Post #644844 Tue Oct 22 2024 6:24pm
Try a fuel filter to see if it fixes the pressure fault code.
Post #644845 Tue Oct 22 2024 6:48pm
Hoverdroid
Okey dokie, i'll change the fuel filter Very Happy
Post #644846 Tue Oct 22 2024 7:06pm
Hoverdroid
Haven't located the fuel filter so far, Wondering if this model actually has one externally. (The mind boggles).
So i bought a more expensive JLR diagnostic tool as the other MUCAR one seemed to be a gimmick.
Here are the codes shown:
PCM
-P0191
-P1335
TCM
-U2023
IPC
-U0159
-U0184
-B1A87
RLM
-U0416
ATCM
-U0401
-U0402
-U0416
PBM
-U0100
VDM
-U0401
The instrument panel is displaying 'F'
The engine seems to be in limp mode (max rpm is 2000)
HDC Fault system - Not available
Transmission fault - limited gears available
Special programs not available
With so many codes and electrical issues i'm not really sure on the best place to start.... any ideas? Rolling Eyes
Post #644957 Tue Oct 29 2024 5:17pm
I'd start by downloading the workshop manual from here: https://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf
That has DTC codes in it (you can search for them) for each system. Also shows you how to do things like the fuel filter. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #644958 Tue Oct 29 2024 6:18pm
Fuel filter under the car.
Approx under drivers seat.
Remove plastic gearbox under tray.
2 types of filter depending on year
Post #644959 Tue Oct 29 2024 7:08pm
U codes are communication problems between modules. Most of the time you can ignore them unless you have serious issues.
The codes should have more digits. -55 as your first post
You had better find the pressure sensor on the fuel rail (top of engine). Inspect wiring and consider changing it once you have done filter
Post #644960 Tue Oct 29 2024 7:41pm
Hoverdroid
Hi Andy, This new diagnostic unit was only giving me said codes (unlike the earlier unit). The Mucar unit didnt have the ability to do any resets so was no good. This new unit has the ability to do all resets. I did manage to reset the EPB system and the transmission adaptation relearn.
After doing that as you could see i still have a vast amount of dtc's to work through. seems to change everytime i scan.
In the morning i'm going to get underneath and check for fuel filter, whilst i'm there i'm going to check multiplugs on transfer box and main gearbox.
I'm also going to order a new fuel rail pressure sensor ( the one on it is new but could be faulty)
Post #644962 Tue Oct 29 2024 9:12pm
Hoverdroid
Located the fuel filter hidden behind a panel by fuel tank. It looks to be a screw on canister type.
From my OLD scanner all i could get with complete codes were:
PCM
P0191 - 24
P0191 - 65
P1335 - 21
Fuel rail pressure according to this unit is: 136730 kpa (Engine off)
TCM
U2023 - 86
The rest dont seem to have any extra digits no matter what i try with the settings on this new diagnostic unit.
U0159
U0184
B1A87
U0416
ATCM
-U0401
-U0402
-U0416 (Invalid data rcvd from VDCM )
PBM
U0100 (Lost com with ECM/PCM 'A' )
I'm going to change the fuel filter and fill up with derv as fuel level is low (yellow light on, but not flashing)
Could anyone let me know what areas are causing limp mode, kinda narrow down my infinite search of errors Laughing
Bow down
Post #644977 Wed Oct 30 2024 5:08pm
Page 1 of 4 1234>
