Home > General > Hi all :) - My 2013 L320 thread
Page 12 of 14 <123 ... 11 121314>
Bertbuckie
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
Can this be done with IID tool? I have misplaced my mongoose cable.
Post #631432 Tue Mar 07 2023 1:53pm
TheWojtek
Look for "Steering sensor renew", the IID manual says it does it for L322, but the manual is kinda old so maybe it is available with your unit. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #631433 Tue Mar 07 2023 1:57pm
Bertbuckie
Cheers. I think it’s my battery causing all, wish the damn thing would hurry up!
First pic is when running for 30 secs. Second is after a few minutes.
Post #631434 Tue Mar 07 2023 2:12pm
NoExpert
That looks fairly normal. After startup the BMS lets things stabilize before it tells the alternator to start pushing power.
How did you get the voltage to display on the dash though? Haven’t seen that before.
Is that the battery health monitoring feature enabled? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #631451 Tue Mar 07 2023 9:14pm
Shows the voltage with the gap tool left in.
Post #631452 Tue Mar 07 2023 10:08pm
NoExpert
Ahh, that would explain it.
By the way, my voltage drops lower than that after startup and I don’t have the issues you’re having, so still in doubt it’s the battery. Unless you’re starting voltage is like 12.3 and drops to 11.5 after startup. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #631455 Wed Mar 08 2023 5:41am
Bertbuckie
Defo battery. Wouldn’t start this morning 😂🙈
Imho anything under 12.3v after a night is extremely low. I really hope it’s just this, faults galore since it started and was defo harder to start the past few weeks.
Post #631458 Wed Mar 08 2023 7:45am
Bertbuckie
IID tool does it when plugged in and that makes sense as to why it stays low a min or two.
Post #631461 Wed Mar 08 2023 8:17am
NoExpert
11.5v before startup, you’re screwed. 11.5v after startup wouldn’t surprise me. 12.6-12.8v overnight is ideal. Mine takes a little beating with the timed heater, but if I check it before it kicks on it’ll show me 12.6-12.8v most mornings, unless it’s down around -10° or lower. I’ll check mine right now as I’m about to leave, although my timed heater is running as I type this. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #631469 Wed Mar 08 2023 4:12pm
Bertbuckie
Aye it’s under 12 to start. Cold here just now, think it was -10 this am. I also agree the times climate finished the battery off, but in fairness it’s 10 years old now so it’s done well. Still no sign of the one I ordered 🙄
Post #631470 Wed Mar 08 2023 4:34pm
NoExpert
Mine read 12.4v just as the timed climate finished its 30 minute run. 12v right after start up. 12.6v about 15 seconds in. 13.4v about 30 seconds in. 14.7v once I started driving a bit.
This is also with the headlights on. Heated seats and steering wheel came on after the 30 second check, voltage didn’t change from that till I started driving. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #631472 Wed Mar 08 2023 5:12pm
Bertbuckie
Well, fecking battery is 5mm too big length and width…. And still got issues turning tho all other issues solved. Fml.
Post #631559 Sat Mar 11 2023 6:52pm
NoExpert
What battery is it? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #631563 Sat Mar 11 2023 8:57pm
There does appear to be a differing opinion on which type battery fits these cars a 019/17 or a 020, which some say they have fitted, however on mine there was no way a 020 was going to fit without forcing it in. The 019 fits straight in the carrier no problem as its about 40mm shorter than the 020, whether it makes a difference not sure but mine is the 5.0L S/C not a diesel.
Post #631564 Sat Mar 11 2023 9:09pm
NoExpert
Mine is 353x175x190 and drops in without too much fuss. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #631570 Sun Mar 12 2023 5:00am
