Home > General > Hi all :) - My 2013 L320 thread |
Bertbuckie Member Since: 04 May 2021 Location: Scotland Posts: 274 |
Can this be done with IID tool? I have misplaced my mongoose cable. |
Tue Mar 07 2023 1:53pm |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
Look for "Steering sensor renew", the IID manual says it does it for L322, but the manual is kinda old so maybe it is available with your unit. Regards etc.,
Tue Mar 07 2023 1:57pm |
Cheers. I think it’s my battery causing all, wish the damn thing would hurry up!
Tue Mar 07 2023 2:12pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 478 |
That looks fairly normal. After startup the BMS lets things stabilize before it tells the alternator to start pushing power.
Tue Mar 07 2023 9:14pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
Shows the voltage with the gap tool left in.
Tue Mar 07 2023 10:08pm |
Ahh, that would explain it.
Wed Mar 08 2023 5:41am |
Defo battery. Wouldn’t start this morning 😂🙈
Wed Mar 08 2023 7:45am |
IID tool does it when plugged in and that makes sense as to why it stays low a min or two. |
Wed Mar 08 2023 8:17am |
11.5v before startup, you’re screwed. 11.5v after startup wouldn’t surprise me. 12.6-12.8v overnight is ideal. Mine takes a little beating with the timed heater, but if I check it before it kicks on it’ll show me 12.6-12.8v most mornings, unless it’s down around -10° or lower. I’ll check mine right now as I’m about to leave, although my timed heater is running as I type this. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed Mar 08 2023 4:12pm |
Aye it’s under 12 to start. Cold here just now, think it was -10 this am. I also agree the times climate finished the battery off, but in fairness it’s 10 years old now so it’s done well. Still no sign of the one I ordered 🙄 |
Wed Mar 08 2023 4:34pm |
Mine read 12.4v just as the timed climate finished its 30 minute run. 12v right after start up. 12.6v about 15 seconds in. 13.4v about 30 seconds in. 14.7v once I started driving a bit.
Wed Mar 08 2023 5:12pm |
Well, fecking battery is 5mm too big length and width…. And still got issues turning tho all other issues solved. Fml. |
Sat Mar 11 2023 6:52pm |
What battery is it? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Sat Mar 11 2023 8:57pm |
There does appear to be a differing opinion on which type battery fits these cars a 019/17 or a 020, which some say they have fitted, however on mine there was no way a 020 was going to fit without forcing it in. The 019 fits straight in the carrier no problem as its about 40mm shorter than the 020, whether it makes a difference not sure but mine is the 5.0L S/C not a diesel.
Sat Mar 11 2023 9:09pm |
Mine is 353x175x190 and drops in without too much fuss. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Sun Mar 12 2023 5:00am |
