![]() | Home > Faults & Fixes > Steering vibration at 70mph + and pulsing brake pedal |
more948 Member Since: 25 Aug 2017 Location: essex Posts: 6 ![]() ![]() ![]() |
It’s and RRS 2.7 tdv6 on an 08 plate |
Genuine discs? Cheap ones warp like cheese Visitor from fullfatrr.com
Not genuine thy were pagids but they were fitted yesterday and no difference at all. |
Stephenrrsport Member Since: 29 Aug 2018 Location: Kilmarnock Posts: 7 ![]() ![]() ![]() |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1876 ![]() ![]() |
Put sensible wheels back on the car? |
The wheels are specificly designed for rr and load rated not cheap Chinese wheels it was 22 wheels that was on it when I got it the wobble has only started past few weeks was fine when new wheels were fitted it’s also Goodyear eagle f1 tyres I’ve had all wishbones and track rods replaced and 4 wheel alignment done by lr and new wheels bearings could it be the steering rack I’ve read on an old post something about a valve on steering rack |
RR but not 2010 Range Rover Sport! |
It was fine with 22” wheels previous so not the wheels that’s the problem and there is loads of people run 22” wheels |
For what it is worth for both of you, try swapping the alloys front to back just as part of the elimination process.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
Wheel balance
Mine does this too. Not always, it appears to be when it’s cold and improves when it’s warm. If I go faster it disappeares. Had all 4 wheels checked twice and I’m now thinking steering rack as it only appears to happen in a straight line. 2019 5.0 SC SVA (Current)
It’s a brand new set of wheels and tyres I’m running only done about 1k so can’t be that I’m also thinking steering rack |
I’ve had all this replaced and wheel alignment done by lr |
Unless you had a bill of close on 4k from LR, its not all been replaced... |
