![]() | Home > Faults & Fixes > Steering vibration at 70mph + and pulsing brake pedal |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 952 ![]() ![]() ![]() |
I used to get the pulsing brake pedal without the steering vibration,, turned out to be a sticky caliper. I had the wheel vibration on a separate occasion and I found the front wheels were slightly oval,,, but you say you have new wheels. 2010 RRS, TDV8
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 ![]() ![]() ![]() |
If the brake pedal moves it has be a problem with the brake pad, disc, hub , or an alignment issue with the hub, upright. Or brake pad carrier alignment sticking calliper / piston.
Not sure what year your car is, i.e. when it was built, but early car steering racks could not even handle 20in rims, let alone 22inch.
Look at TSB X3 Wheel Shimmy
