Home > Faults & Fixes > Steering vibration at 70mph + and pulsing brake pedal |
more948 Member Since: 25 Aug 2017 Location: essex Posts: 6 |
It’s and RRS 2.7 tdv6 on an 08 plate |
Sun Jun 03 2018 8:25pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Genuine discs? Cheap ones warp like cheese Visitor from fullfatrr.com
Sun Jun 03 2018 8:49pm |
Not genuine thy were pagids but they were fitted yesterday and no difference at all. |
Sun Jun 03 2018 8:50pm |
Stephenrrsport Member Since: 29 Aug 2018 Location: Kilmarnock Posts: 7 |
Wed Aug 29 2018 6:43pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1845 |
Put sensible wheels back on the car?
Wed Aug 29 2018 6:47pm |
The wheels are specificly designed for rr and load rated not cheap Chinese wheels it was 22 wheels that was on it when I got it the wobble has only started past few weeks was fine when new wheels were fitted it’s also Goodyear eagle f1 tyres I’ve had all wishbones and track rods replaced and 4 wheel alignment done by lr and new wheels bearings could it be the steering rack I’ve read on an old post something about a valve on steering rack |
Wed Aug 29 2018 7:03pm |
RR but not 2010 Range Rover Sport! 2023 P440e SE Dynamic on order -cancelled
Wed Aug 29 2018 7:06pm |
It was fine with 22” wheels previous so not the wheels that’s the problem and there is loads of people run 22” wheels |
Wed Aug 29 2018 7:11pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
For what it is worth for both of you, try swapping the alloys front to back just as part of the elimination process.
Thu Aug 30 2018 5:27am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4417 |
Wheel balance
Thu Aug 30 2018 6:05am |
Mine does this too. Not always, it appears to be when it’s cold and improves when it’s warm. If I go faster it disappeares. Had all 4 wheels checked twice and I’m now thinking steering rack as it only appears to happen in a straight line. 2019 5.0 SC SVA (Current)
Thu Aug 30 2018 6:46am |
It’s a brand new set of wheels and tyres I’m running only done about 1k so can’t be that I’m also thinking steering rack |
Thu Aug 30 2018 7:39am |
I’ve had all this replaced and wheel alignment done by lr |
Thu Aug 30 2018 7:41am |
Unless you had a bill of close on 4k from LR, its not all been replaced... |
Thu Aug 30 2018 12:01pm |
