Home > Faults & Fixes > Steering vibration at 70mph + and pulsing brake pedal
more948
United Kingdom 2008 Range Rover Sport TDV6 SE Java Black
Guys I have a strange problem Iv being trying to sort for a few weeks now.
I have a constant pulsing through the break pedal when applying the brakes and a steering wheel wobble at 70mph +.
So far I have done the following:
New front discs and pads
Replaced the rear upper arms as a bush had failed
Balanced all wheels
4 wheel alignment.
The front lower arms bushes were replaced with poly bushes about 2000miles a go.
Any other ideas?
Post #558066 Sun Jun 03 2018 8:25pm
more948
It’s and RRS 2.7 tdv6 on an 08 plate
Post #558067 Sun Jun 03 2018 8:25pm
DrRob
Genuine discs? Cheap ones warp like cheese Visitor from fullfatrr.com
Post #558072 Sun Jun 03 2018 8:49pm
more948
Not genuine thy were pagids but they were fitted yesterday and no difference at all.
Post #558073 Sun Jun 03 2018 8:50pm
Stephenrrsport
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Steering wobble
Hi I’m having the same problem fitted new 22” wheels and tyres and I’m getting a wobble as soon as it hits 55mph and can’t drive through it I’m at my wits end with it mine is a 2010 has anybody managed to fix this
Post #564146 Wed Aug 29 2018 6:43pm
jimbg
Put sensible wheels back on the car? Whistle
What was it like before you fitted those wheels? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #564147 Wed Aug 29 2018 6:47pm
Stephenrrsport
The wheels are specificly designed for rr and load rated not cheap Chinese wheels it was 22 wheels that was on it when I got it the wobble has only started past few weeks was fine when new wheels were fitted it’s also Goodyear eagle f1 tyres I’ve had all wishbones and track rods replaced and 4 wheel alignment done by lr and new wheels bearings could it be the steering rack I’ve read on an old post something about a valve on steering rack
Post #564149 Wed Aug 29 2018 7:03pm
jimbg
RR but not 2010 Range Rover Sport! Thumbs Up 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #564150 Wed Aug 29 2018 7:06pm
Stephenrrsport
It was fine with 22” wheels previous so not the wheels that’s the problem and there is loads of people run 22” wheels
Post #564151 Wed Aug 29 2018 7:11pm
Stevepd
For what it is worth for both of you, try swapping the alloys front to back just as part of the elimination process.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #564168 Thu Aug 30 2018 5:27am
Disco_Mikey
Wheel balance
Worn TRE's or rack
Lower arm bushes
Alignment
Warped discs/hub
Post #564169 Thu Aug 30 2018 6:05am
Brit Plumber
Mine does this too. Not always, it appears to be when it’s cold and improves when it’s warm. If I go faster it disappeares. Had all 4 wheels checked twice and I’m now thinking steering rack as it only appears to happen in a straight line. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #564170 Thu Aug 30 2018 6:46am
Stephenrrsport
It’s a brand new set of wheels and tyres I’m running only done about 1k so can’t be that I’m also thinking steering rack
Post #564171 Thu Aug 30 2018 7:39am
Stephenrrsport
Disco_Mikey wrote:
Wheel balance
Worn TRE's or rack
Lower arm bushes
Alignment
Warped discs/hub
I’ve had all this replaced and wheel alignment done by lr
Post #564172 Thu Aug 30 2018 7:41am
Disco_Mikey
Unless you had a bill of close on 4k from LR, its not all been replaced...
Post #564184 Thu Aug 30 2018 12:01pm
