Home > Maintenance & Modifications > LED Lighting
Page 5 of 5 <12345
tanloverluke
Gaz wrote:
Have you flipped the ones that aren't working ?
yep, flipped them. if i have them one way the 4 led's on the top start to slowly burn & die and the side led's don't illuminate, if i have them the other way the 4 led's on the top don't illuminate yet the 4 on the sides do.
problem is that i don't have anything to test them on. so little stuck right now and no-one in my village has a land rover that i can test them in.
if only i had your luck guys ! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #401225 Wed Nov 06 2013 11:24am
jack.bauer
http://pages.ebay.com/link/?nav=item.view&id=150931319404
Bought these but won't fit. I'm sure I got this recommended from one of threads on here but can't find the reference.
What should I actually have got as brake light bulbs? 07 TDV8 + BAS map
Post #413197 Sun Feb 09 2014 4:15pm
originalkadok
so I have just bought the LEDs' for mine, looking forward to them arriving.
Post #413943 Fri Feb 14 2014 8:29am
StrangeRover
Ordered and now patiently waiting for them to arrive Rolling Eyes , any difficult/tricky locations I should be aware of thanks
Post #415540 Wed Feb 26 2014 1:22am
Glovebox, near impossible to get old bulb out. Mr. Green
Rear passanger side, wire will disappear into the headlining when you disconnect the light fitting. Long nose pliers required to retrieve it. Banging Head
Vanity mirrors, mine kept blowing fuses when trying to swap the bulbs over because the lights come on as you open the vanity mirror causing the bulb to short out when trying to fit new bulb. Worth getting some spare fuses just incase, or take out the fuse before fitting new bulbs. Wink
Other than that, its straight forward. Thumbs Up
Post #415571 Wed Feb 26 2014 10:57am
fkarim
Follow this to replace glovebox bulb easily.
Post #415591 Wed Feb 26 2014 1:37pm
StrangeRover
Ok thanks for the heads up guys ! Thumbs Up
Post #415897 Fri Feb 28 2014 12:34am
riverblanche
Hi,
I have just got some of the 5led bulbs and replaced the ones in the doors first
easy peasy to do them Whistle front door done first old one still in the rear
change some more at the weekend
changed 10 now had been thinking about getting a brighter one for the boot, but ones I had been watching have gone from £7.99 to £17.89 now Shocked Shocked they must be selling well Question
the ones I did buy are
http://www.ebay.co.uk/itm/160943410073?ssP...1497.l2649
10 for £7.19
Post #415991 Fri Feb 28 2014 11:42pm
Techstyles
Belgium 2005 Range Rover Sport TDV6 HSE Maya Gold
Hi Fellas,
Does anybody know what LED's to use for the front side bulbs and whether there are any tutorials or guides for it? Wondering how easy it is to replace the bulbs.
Already did the interior which was pretty easy.
Thanks
Justin
Post #451399 Thu Feb 05 2015 3:01pm
Wayneclarke
HICKY555 wrote:
ORDERED THE REAR BOOT INTERIOR Thumbs Up One light you forgot!!! the ashtray Very Happy Very Happy Very Happy Very Happy Very Happy
what bulb do you use for this light and how do you change it ?..
Post #451486 Thu Feb 05 2015 10:17pm
Techstyles
its a normal W5W T10 501, i would recommend a SMD 13 as there is only one light so you want it to be pretty bright. A 5SMD isnt enough imho.
Post #451538 Fri Feb 06 2015 9:29am
Wayneclarke
And how do I get the lighter socket out to change the bulb ?
Post #451541 Fri Feb 06 2015 9:44am
Techstyles
Oh sorry mate, I thought you were asking about the rear interior light.
No idea on the lighter bulb, I just left mine as is. Have you tried to pop it out?
Post #451542 Fri Feb 06 2015 9:52am
Page 5 of 5 <12345
