![]() | Home > Maintenance & Modifications > LED Lighting |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 ![]() ![]() ![]() |
well, this 'Crazy LED' seller on ebay is selling all the LED bulbs for the FFRR for . . . . . . £62, and has sold LOADS !!
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
So this is where I am with my led's. Only four illuminating. Your lights are very bright Gaz. The ebay seller said this was normal though, but now I am very confused !!! |
karan538 Member Since: 30 Oct 2012 Location: uk Posts: 89 ![]() ![]() |
Can anyone let me know if these would fit ALL around in the interior.
JPR 1 Member Since: 29 Jan 2013 Location: Cheshire Posts: 435 ![]() ![]() ![]() |
Thanks Brian, finally a cheap easy upgrade.
those 9 LED ones on Amazon are small enough to do all, except I don't know about cigar lighter and vanity mirrors, as never changed mine. But, the larger internal ones I used 13 LED's for. The brighter the better ! |
SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 540 ![]() ![]() ![]() |
http://www.ebay.co.uk/itm/20xT10-5050-W5W-...4ac70b6b9e
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289 ![]() ![]() |
If you want bright, put a 30 SMD panel in your centre front and middle lights!
Just done mine this morning looks great...but broke the rear number plate bulb holder |
Installed mine,
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Doesn't sounf right. |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 ![]() ![]() ![]() |
All my interior ones are fitted now and are working fine. No battery drain problems.
Gaz i wish i could help you with your second problem but im still stuck on my first problem !
Have you flipped the ones that aren't working ? |
Does seem strange, all mine worked fine? Current Volvo XC90 R Design T8
