Home > Maintenance & Modifications > LED Lighting |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
yep, flipped them. if i have them one way the 4 led's on the top start to slowly burn & die and the side led's don't illuminate, if i have them the other way the 4 led's on the top don't illuminate yet the 4 on the sides do. problem is that i don't have anything to test them on. so little stuck right now and no-one in my village has a land rover that i can test them in. if only i had your luck guys ! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project. DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
Wed Nov 06 2013 10:24am |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 |
http://pages.ebay.com/link/?nav=item.view&id=150931319404
Sun Feb 09 2014 3:15pm |
originalkadok Member Since: 05 Feb 2014 Location: Maidenhead Posts: 8 |
so I have just bought the LEDs' for mine, looking forward to them arriving. |
Fri Feb 14 2014 7:29am |
Glovebox, near impossible to get old bulb out.
Wed Feb 26 2014 9:57am |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
Follow this to replace glovebox bulb easily. |
Wed Feb 26 2014 12:37pm |
StrangeRover Member Since: 22 Feb 2014 Location: London Posts: 27 |
Ok thanks for the heads up guys ! |
Thu Feb 27 2014 11:34pm |
Fri Feb 28 2014 10:42pm |
Techstyles Member Since: 22 Dec 2014 Location: Antwerp Posts: 46 |
Hi Fellas,
Thu Feb 05 2015 2:01pm |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 |
what bulb do you use for this light and how do you change it ?.. |
Thu Feb 05 2015 9:17pm |
its a normal W5W T10 501, i would recommend a SMD 13 as there is only one light so you want it to be pretty bright. A 5SMD isnt enough imho. |
Fri Feb 06 2015 8:29am |
And how do I get the lighter socket out to change the bulb ? |
Fri Feb 06 2015 8:44am |
Oh sorry mate, I thought you were asking about the rear interior light.
Fri Feb 06 2015 8:52am |
