Home > Technical > Big Fuelling Issue
Page 2 of 5 <12345>
jdgeary1
2006 Range Rover Sport TDV6 HSE Sumatra Black
Ok so not an air lock, they have now removed all the interior and carpets and checked all the cabling and wiring as well as taken the fuel tank out, but no faults found.
What the hell can it be, its madness......
Post #388033 Sun Jul 07 2013 9:11am
muddywheels
Milk Float Man
Hope they find out soon - must be costing you a fortune Shocked
I find it incredible reading posts like yours that when these "premium" vehicles "engineered for optimum performance" go wrong the Lr "trained technicians" seem to be at a loss how to fix them Rolling Eyes Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #388037 Sun Jul 07 2013 10:31am
drdelrrs
I think. like many professions, no-one wants to give advice in fear on being on the end of litigation when its the wrong decision.
So your LR technician will just report what the diagnostics register; just like those telephone support staff on the end of the Freephone help desk numbers and work for any organisation "its the system Sir I can't change it..." Big Cry
Just think that with most RRS's coming in at £75k or more no dealer will go out on a limb when problems occur we'd better hope that the reliability has been hiked as high as the price !
Post #388067 Sun Jul 07 2013 6:30pm
jdgeary1
Well saga continues, Range Rover/Land Rover cannot diagnose the fault, they are stumped!!!!
What the hell do you do now, when the manufacturer's top bods cannot diagnose a problem.......
Sue?
Post #388819 Sun Jul 14 2013 9:46am
muddywheels
Milk Float Man
Vehicle is unfit for purpose so I would be looking for refund or replacement Evil or Very Mad Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #388820 Sun Jul 14 2013 9:51am
jdgeary1
That's what Ive told the garage I purchased it from, but its madness that Land Rover cannot rectify the fault and cant even diagnose it.
I have never in my life of car ownership know an issue like this.
The legal aspect will be considered, as I have had the car 7 months although this fault was there pretty much from the start but has taken so long to get it into be looked at, having spent time in the garage already for a replacement turbo initially, then diagnosed my range rover and now having been in the garage just over a month also trying to be sorted out.
Post #388824 Sun Jul 14 2013 10:25am
muddywheels
Milk Float Man
Sadly you are now part of a growing group on here Sad
Can't help feeling that we are paying large sums to be testers for all the new technology being fitted by JLR Big Cry Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #388826 Sun Jul 14 2013 10:36am
H16UUP
United Kingdom 2006 Range Rover Sport TDV6 SE Zermatt Silver
Did they replace the fuel pressure sensor in the end? Also, it would help if you could get the fault codes from the technicians & let us know them. Have they ruled out the EGR valves or is it definitely low fuel pressure? 2006 TDV6 SE, Zermatt Silver
Post #389116 Wed Jul 17 2013 8:02pm
Drop test -CHECK
scratch test -CHECK
interior colour - N/A
Interior swap -CHECK
NEW CAR - TBA
Post #389119 Wed Jul 17 2013 8:17pm
jdgeary1
The fault code related to something called Fuel Deviation. It seems to happen intermittently and also under load, as it seems ok on a ramp running the car.
Not sure on the fuel sensor, I will check on that one.
EGR Valves were replaced literally maybe 1000 miles ago.
Post #389250 Thu Jul 18 2013 6:36pm
jdgeary1
Checked, Fuel Pressure Sensor has been replaced also, checking on the actual fault code but am sure he said it was fuel deviation. They have checked the fuel pressures as there is a drop off 5 bar to 2 bar or something similar, not 100% sure, but it should be higher and it drops low.
All fuel lines checked and cleaned, tanks been out, both pumps replaced, electrics have been checked and tested by a Range Rover tech guy.
The warning code maybe p2290-00 but he is double checking in the morning for me to confirm, but is sure that was it off the top of his head.
Post #389252 Thu Jul 18 2013 6:47pm
jdgeary1
Oh and the car is at Rover Tune in Reading, Rob is pulling his hair out if anyone can HELP..........
If anyone knows some possibilities and knows Rover Tune, Rob, any help would be grateful. 6 weeks now the car has been there and currently no sign of being sorted. Totally baffled...........
Post #389253 Thu Jul 18 2013 6:48pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Inter cooler hose Collapsing and starving the car of air no air=no need for fuel seen it before on scoobys and Evo's
Post #389255 Thu Jul 18 2013 7:11pm
Bobby
jdgeary1 wrote:
...The warning code maybe p2290-00 ...
P229000 - Injector Control Pressure Too Low
Probable Causes:
• Fuel pressure control valve (FPCV) maximum limit reached
• Fuel injector control pressure too low
• Fuel line leak
• Fuel filter/system restriction
• FPCV circuit fault
• FPCV failure
• Fuel pump module circuit short circuit to ground
• Fuel pump module failure
• Fuel injection pump failure
What to do:
Check the fuel pressure.
Check the fuel lines for leaks/damage.
Check for a blocked/restricted fuel filter.
Check the fuel pump module circuits.
Check the FPCV circuits.
Check the fuel injection pump. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #389263 Thu Jul 18 2013 8:29pm
Coxylad
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
If you take your car to a garage to be fixed and they change a part that didn't need changing because they got it wrong why should you have to pay for it??
When they finally find the problem and fix it then you pay just for that bit.
You are paying for there training 2007 RANGE ROVER SPORT 2.7 TDV6 HSE in silver
Post #389290 Fri Jul 19 2013 10:15am
Page 2 of 5 <12345>
