Home > Maintenance & Modifications > Is the transfer box a servicable item?
Mike_C
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Tangiers Orange
Or more specifically, is the actuator replacable on it's own and is it a full strip-down job on the transfer box to replace it?
Many thanks! - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
- BMW 330Ci M-Sport coupe
- Suzuki GSX-R750 K6 'Stealth' - trackdays and high speed tourer
Post #369778 Thu Jan 17 2013 3:17pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Not sure if this thread might give you a clue?
http://www.disco3.co.uk/forum/topic47890.html Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
http://rrsport.co.uk/forum/topic28424.html
Post #369823 Thu Jan 17 2013 7:01pm
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
Looks like the actuator can be changed, it's an external part. You may still have to drop the transfer box though, no idea if the actuator is accessible with the box in situ.
"Roads ? Where we're going there are no roads." Back to the future.
Post #369876 Thu Jan 17 2013 10:34pm
Disco_Mikey
The actuator can be replaced, but needs to be calibrated using a the correct diagnostic machine.
Before jumping to that though, check the transfer case ECU for water ingress and corrosion. Common issue with these cars
Post #371018 Sat Jan 26 2013 9:03am
