Home > Technical > Definitive list of 'HOW TOs'
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hi All,
I think it would be handy to have a single post with as many 'how to' guides as possible as a first port of call before people ask the same questions over and over.
Here are a few I have found on my travels. I know there are many more but there is only so much time in the day.
This would have to be a group effort so if you guys can post links in here and I'll add them to the first post then maybe a mod can sticky it.
Here goes...
Literarure
Discovery 3 workshop manual
http://landrover.workshop-manuals.com/lr3/index.php?id=2521
Front diff breather pipe TSB
http://www.disco3.co.uk/gallery/albums/use...b00245.pdf
Brakes
Bodsy's Brake Bible (need to register on disco3 site to view)
http://www.disco3.co.uk/gallery/thumbnails.php?album=4184
Rear discs, pads and EPB adjustment
http://www.disco3.co.uk/forum/topic25409.h...nge+bushes
EPB (Electronic Park Brake) repair/Unjam + Relatch
http://www.disco3.co.uk/forum/topic91299.html
How to change Brembo pads
http://www.rrsport.co.uk/forum/topic2458.html
Emergency Park Brake Release
http://www.rrsport.co.uk/forum/topic17273.html
Steering and Suspension
Front suspension torque settings:
http://www.rrsport.co.uk/gallery/albums/us...ension.jpg
How to change wishbone (lower arm) and track (tie) rod end
http://rrsport.co.uk/forum/post363424.html#363424
How to change wishbone (upper arm)
http://www.disco3.co.uk/gallery/albums/use...hbones.pdf
Wheel bearings
http://www.rrsport.co.uk/forum/topic28421.html
Lower ball joints
http://www.disco3.co.uk/forum/topic31160.html
Steering column UJ replacement
http://www.disco3.co.uk/forum/topic56798.h...teering+uj
AMK Suspension Compressor Replacement
http://www.rrsport.co.uk/forum/post358187.html#358187
Compressor renewal and cleaning
http://www.disco3.co.uk/forum/post799075.html#799075
Front suspension valve cleaning (Suspension lowering overnight)
http://rrsport.co.uk/forum/topic29358.html
Replacing Anti Roll Bar bushes
http://disco3.co.uk/forum/topic61491.html?highlight=diff
Fitting Anti roll bar bush spacers to stop knocking
http://www.disco3.co.uk/forum/topic30622.html
Engine and gearbox
TDV6 Oil Change
http://www.disco3.co.uk/wiki/index.php/TDV6_Oil_Change
TDV6 Timing Belts
http://www.disco3.co.uk/forum/topic53674.html
EGR replacement
http://www.disco3.co.uk/forum/topic31658.html
EGR Blanking
http://www.disco3.co.uk/gallery/albums/use...s%20D3.pdf
TDV6 Alternator Replacement
http://disco3.co.uk/forum/topic82516.html
http://www.aulro.com/afvb/d3-d4-rrs/69060-...ement.html
Turbo Replacement
http://www.rrsport.co.uk/forum/topic29087.html
Coolant bottle/resevoir replacement (low coolant message)
http://rrsport.co.uk/forum/post377023.html#377023
Autobox Gear Lever Pivot
http://disco3.co.uk/forum/topic31656.html?highlight=autobox+pivot
Fuel Filter and Diff Oil Change
http://www.disco3.co.uk/forum/topic32281.html
Front Diff Breather Pipe Vent Replacement/Upgrade
http://rrsport.co.uk/forum/post377031.html#377031
Replacement of Transfer Box Seals
http://www.disco3.co.uk/forum/topic47890.html
EPB and Gearbox Release
http://rrsport.co.uk/forum/topic28592.html
FBH - Fuel Burning Heater (Reset and diagnostics)
http://www.disco3.co.uk/wiki/Fuel_Burning_Heater
Body and trim
Body Shell removal
http://www.disco3.co.uk/forum/topic76002.html?highlight=body
Headlight Removal
Colour coordinated headlights
http://rrsport.co.uk/forum/topic25871.html?highlight=detangod
Removing Headlamp Washers
http://www.rrsport.co.uk/forum/post350621.html#350621
Side Vent Removal
http://www.rrsport.co.uk/forum/topic5448.html
&NR=1
2010+ models
&feature=relmfu
Door Handle Cover Removal
&feature=endscreen&NR=1
How to replace front bumper cross member
&feature=BFa&list=UUjCbH52t-y0TPd6Y4CElvFw
How to Remove Rear Bumper
&feature=relmfu
How to Remove the A Pillar
&feature=relmfu
How to Remove D Pillars
How to remove the rear spoiler
&feature=share&list=PL8B8F797C102C869E
How to replace the upper tailgate panel on the Range Rover Sport 2005-2011
How to fit LED rear number plate bulbs
&list=PL8B8F797C102C869E&index=116&feature=plpp_video
How to fix a leaking sunroof
http://www.disco3.co.uk/forum/topic22757.html
How to fit LED Mirror Covers
Part 1
&feature=relmfu
Part 2
&feature=relmfu
How to Change side repeater (indicator)
&list=PL8B8F797C102C869E&index=11&feature=plpp_video
How to change front fog lamp bezels
&list=PL8B8F797C102C869E&index=43&feature=plpp_video
How to fit side step on RRS
part 1
&feature=relmfu
Part 2
&feature=relmfu
How to fit Autobiography spoiler to 2005-2009 RRS
&list=UUjCbH52t-y0TPd6Y4CElvFw&index=1&feature=plpp_video
Twin electrics (towing trailer)
http://www.rrsport.co.uk/forum/topic29704....6377e0903b
Interior
How to remove front door card
How to replace RHS door latch and/or window regulator (Door doesn't lock/unlock)
http://disco3.co.uk/forum/topic33743.html?...lock%5C%22
How to replace rear door latch (check part numbers for RRS)
http://www.disco3.co.uk/wiki/Rear_Door_Latch_Replacement
Removing Instrument Cluster
http://www.rrsport.co.uk/gallery/albums/us...luster.pdf
How to fit alloy foot pedal covers
&list=UUjCbH52t-y0TPd6Y4CElvFw&index=18&feature=plpp_video
How to change the interior air vent trim
How to change the radio side panels
&list=PL8B8F797C102C869E&index=4&feature=plpp_video
How to remove gear knob
&list=PL8B8F797C102C869E&index=14&feature=plpp_video
How to remove centre console on Range Rover Sport 2005-09
&list=PL8B8F797C102C869E&index=2&feature=plpp_video
How to remove Stereo / Heater contols
&list=PL8B8F797C102C869E&index=3&feature=plpp_video
How to change steering wheel (Guidance Only)
&list=PL8B8F797C102C869E&index=36&feature=plpp_video
Electrical Interior
How to reset Service Alert (Some models)
http://www.rrsport.co.uk/forum/topic18906.html
Mod to make rear map/reading lights come on when doors open
http://www.rrsport.co.uk/forum/topic20566.html
http://www.rrsport.co.uk/forum/topic5537-45.html
Disabling seatbelt chime
http://www.rrsport.co.uk/forum/topic24629.html
Android "unfortunately bluetooth share has stopped" error fix (Phonebook sync via bluetooth)
http://rrsport.co.uk/forum/post370048.html#370048
Constant Power to 12v Sockets
http://www.rrsport.co.uk/forum/topic12783.html
Twin iPOD lead installation
http://www.rrsport.co.uk/forum/topic28159.html
http://www.rrsport.co.uk/forum/topic20919.html?highlight=
Hardwiring a radar detector
http://www.rrsport.co.uk/forum/topic10937.html
Trailer light hookup
http://www.rrsport.co.uk/forum/topic5581.html
Bluetooth Module Swap
http://www.bluetoothexchange.co.uk/help/sport.html
How to change Glovebox light to LED
http://www.rrsport.co.uk/forum/topic12849.html
Ignition Key Rechargeable Battery - Replacement
http://www.disco3.co.uk/forum/topic63124.html
Hifi / telephone on satnav screen INCLUDING brightness fix
http://www.disco3.co.uk/forum/topic74474.html
Rear window demister defroster heater fix
http://rrsport.co.uk/forum/topic29082.html
Post #358838 Fri Oct 05 2012 3:13pm
Bodsy
Site Sponsor
You haven't found my brake bible then....? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #358851 Fri Oct 05 2012 5:49pm
Disco_Mikey
Nice to see some of my How-To's have made it over Thumbs Up
Post #358864 Fri Oct 05 2012 9:33pm
kav1187
Guess I'll have to look for it eh? Laughing
Yes Mikey your air compressor one was an inspiration Smile
Post #358867 Fri Oct 05 2012 10:24pm
kav1187
Does anyone know of any more?
Post #361676 Fri Nov 02 2012 8:59pm
flydive
EPB and gearbox release
http://rrsport.co.uk/forum/topic28592.html '08 RRS TDV8
Post #361679 Fri Nov 02 2012 9:20pm
Bob.
http://www.disco3.co.uk/forum/topic63124.h...+%2Bcasing
Mods - How about making this thread a sticky?
Post #361684 Fri Nov 02 2012 10:51pm
kav1187
Thanks for the suggestions chaps, they have been added.
Also thanks to the mods for sticky-ing. Thumbs Up
Any more please let me know...
Post #362021 Tue Nov 06 2012 12:49am
Disco 3 workshop manual online:
http://landrover.workshop-manuals.com/lr3/index.php?id=1
Obviously some of this will not be helpful when working on the RRS but some will be because of the shared nature of the components in both types. 2012 SDV6 - it's missing a couple of cylinders
Post #365085 Sat Dec 01 2012 7:47pm
kav1187
Thanks RRSTDV8 Thumbs Up
New section added for literature - any general manuals will be added to this section. Anything specific will go to the relevant sections. Thumbs Up
Keep 'em coming folks! Bow down
Post #367858 Fri Dec 28 2012 2:05pm
1014rk
MY 2011 tow bar electrics HELP
Hi, I have bought tow bar electrics from Duckworth landrover spares, VPLST0014. I am attempting to fit the loom at the passenger side behind the trim panel. I have got to step 8/9, and the instructions say to remove the section of loom and bin it, and replace with new loom.
Problem is I have a spare bit of loom which goes down to the bumper, and it is not unplugable. This is not the cable which is marked rear bumper and has the plug, but it is loomed in with the bit I need to remove.
Do I have the wrong part.
My car wiring loom has checked stickers dated 18/10/10, and was registered dec 2010.
Thanks in advance
Russ MY 2014 3.0 SDV6 HSE Dynamic
Causeway Gray
My2011 3.0 TDV6 HSE Luxury Nara Bronze (gone)
Post #370135 Sat Jan 19 2013 6:14pm
Disco_Mikey
How To - EPB repair/Unjam + Relatch
Post #374792 Tue Feb 26 2013 8:08am
Nice one DM Thumbs Up
Wouldn't like to try this without a decent vehicle lift though... 2012 SDV6 - it's missing a couple of cylinders
Post #374814 Tue Feb 26 2013 11:18am
kav1187
Thanks Mikey - it has been added Thumbs Up Thumbs Up Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
http://rrsport.co.uk/forum/topic28424.html
Post #377025 Fri Mar 15 2013 2:05pm
digger1970
England 2005 Range Rover Sport TDV6 HSE Bonatti Grey
Brilliant.... no more main stealers for me!!! Thanks to all
Post #411949 Fri Jan 31 2014 8:56am
