Home > Faults & Fixes > RRS SDV6 3.0D Restricted Performnce error code p22d2 p22cf |
Heremyjill Member Since: 01 Jun 2020 Location: Shrewsbury Posts: 89 |
Good afternoon,
Sat Jul 27 2024 2:34pm |
Good morning all.
Wed Jul 31 2024 8:16am |
Good morning all.
Tue Sep 17 2024 7:07am |
Woody91 Member Since: 17 Feb 2024 Location: Norfolk Posts: 12 |
Glad you've found a solution.
Tue Sep 17 2024 11:39am |
Jonsey Member Since: 04 Jan 2025 Location: Suffolk Posts: 4 |
Hi, I am deep into the dreaded restrictive performance state following a pin hole in top water hose, caused by the JLR fitted protective sleeve moving and the sound proofing cover cutting into hose. When replacing hose, the thermostat manifold fell to pieces, requiring a replacement.
Tue Jan 07 2025 10:39am |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 152 |
You pic is of the EGR Cooler Bypass Actuator which is vacuum controlled. There is an EGR unit on either side of the engine.
Tue Jan 07 2025 12:37pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4415 |
TSOV is the actuator on the back of the secondary turbo
Tue Jan 07 2025 12:43pm |
Sorry DM, you're totally correct TSOV is rear of turbo, I think his problem is more likely the CSOV as it's had a coolant maniflold change.
Tue Jan 07 2025 12:53pm |
Thank you Disco-Mickey and 2RRS for your informative and prompt replies. I will look into it and post an update, so others benefit. Appreciate your help. |
Tue Jan 07 2025 1:54pm |
I'm voting for a vac pipe under the throttle body first, pr the vac pipe from the solenoid to rad pack as a second guess |
Tue Jan 07 2025 6:25pm |
I'd concur, the vacuum pipe from the solenoid to the csov is quite brittle and is a prime candidate to get clobbered doing the coolant manifold. I'm sure you see enough brittle pipes day to day! |
Tue Jan 07 2025 6:37pm |
Update for 2 RRS and Disco-Mikey who helped me in my search to resolve the dreaded 'Restrictive Performance' on RR Sport TDV6 2010.
Tue Jan 14 2025 9:45pm |
Glad you got it sorted & a cheap fix!! |
Tue Jan 14 2025 9:51pm |
Feeling lucky with fix, hope this helps others locate the problem and save the stress involved not knowing. |
Tue Jan 14 2025 10:04pm |
