Home > Maintenance & Modifications > What a total |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 316 |
Alternator has a horizontal bolt going in from the front, access from the top, and two vertical bolts accessed from below. Don’t remember a bracket, but if it was obvious/easy I may have forgotten about it. |
Mon Dec 30 2024 9:52pm |
Axl Member Since: 20 Nov 2024 Location: Ayr Posts: 62 |
I know I can get that easy it's the bottom ones, the weather's been hellish here though and working outside. |
Mon Dec 30 2024 11:13pm |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 388 |
Did you speak to RR Glasgow ? |
Mon Jan 06 2025 12:50pm |
Yes but don't fit anything a customer supplies. |
Mon Jan 06 2025 2:06pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Insurance liabilities. We are the same... |
Mon Jan 06 2025 3:16pm |
So unless i can get the one I've got on I'm stuck, I'll get photos on it tomorrow and probably sell it. |
Mon Jan 06 2025 4:14pm |
You'll see above i did and what they said I also got the RAC out tonight mainly to see if they would offer their mobile mech to fix it. Said no it'd need to go to a garage but also said the power steering pulley's loose and that's what's broke the alt belt and put the light on. Thing is, I looked at a few engine photos and the steering pump's on the opposite side. I then thought it was the water pump but no. This is a pulley not directly under the alt but dam near. There's 2 belts on mine, one goes round the alt, tensioner, crank then this other thing. The other longer one goes round the fan, crank, p/ steering and an idler. So what Mr rac said is the steering pump no its not. He also said why don't you if you've got a new one (belt) put it on just to see if the alt is ok but said I'm sure i remember seeing and smelling smoke. I honestly don't know what the hell to do with this thing. I like it but it lasted 1 week 1 bloody week then this crap. But the main thing really pi55in me off is the tax is 770 (paying up). |
Tue Jan 07 2025 1:21am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4984 |
There’s an ACE suspension pump near the alternator.
Tue Jan 07 2025 5:30am |
You're right I'm sure that's what it is, Mr RAC obviously hadn't heard or didn't about it. I googled it a bit a see some bypass it but can cause problems.
Tue Jan 07 2025 10:34am |
I see Jonny hasn't answered yet about if i phoned the place in glasgow, or maybe he's no answer too as i think he was sure they'd fit mine, wrong
Wed Jan 08 2025 1:49am |
Did the belt break?
Wed Jan 08 2025 2:47am |
Yes but don't know if it was because the ace pulley's loose or a worn/ maybe sticky alt pulley. My guessing is maybe it being loose has been biting into it.
Wed Jan 08 2025 11:10am |
Yes, and If you take it to an independent specialist garage, they can do a proper inspection and tell you want it required.
Wed Jan 08 2025 12:34pm |
A garage will only fit new that they supply. I might (weather permitting) try and get the new belt on for the hell of it just to see what happens and if the alt starts smoking etc again then it's it's getting to get the new one one.
Wed Jan 08 2025 3:06pm |
