![]() | Home > Maintenance & Modifications > What a total |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 430 ![]() ![]() |
Where exactly are you in Scotland ? Must be someone who knows someone. |
Axl Member Since: 20 Nov 2024 Location: Ayr Posts: 73 ![]() ![]() |
Glasgow I've got the number of someone in Ayrshire so will ask. |
Thanks I've not heard of them but will ask on Monday. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4440 ![]() ![]() ![]() |
RAC wouldn't do something like that roadside. They'd only recover you to a garage or home, but I do like your thinking |
I know they (AA in my case) won't fit it at the roadside but they'll book it in for a mech to come out and do it and wondered if they did it.
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 952 ![]() ![]() ![]() |
Certainly easier to get it out than put it back in,, trying to put the bottom bolts in last is next to impossible,, I resorted to putting the two bottom bolts in place on the alternator then put the alternator back in place,,,, and don't let the bolts slip out in the process. Hang it off the top bolt then a short 13mm half a turn at a time to do the bottom ones. 2010 RRS, TDV8
I can't get even get the bloody thing out never mind the new one in! |
It is a bit a tight fit,, you need to rotate it and it will come out beside the ACE pipes 2010 RRS, TDV8
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 317 ![]() ![]() ![]() |
It’s a pita. Mine caught fire and I was thinking about doing it in the hotel car park. Called my mechanic and he told me I probably didn’t want to try that.
Sorry what i mean is, I can't get the bottom pipe off that's right against the 2 10mm bolts at the alt, well I can (the one that's attached to the metal pipe) i think to the turbo if not it's a coolant pipes and don't want it (coolant from another pipe) in my eyes again. I guess if I got that or the way then I could probably start fighting getting the alternator out etc. Last edited by Axl on Sat Dec 28 2024 9:09pm. Edited 1 time in total |
Thanks for your explanation on how you did it. I bought the proper 36mil spanner and getting the fan, shroud, pipes etc was really quite easy, watching what I was doing though working close to the rad. As I was saying above, it's mainly (well so far) the pipe connected to the metal pipe in wary of loosening incase of a coolant pipes and get it in my eyes again (bloody stung and got a fright incase it did something to my sight). What's NLA |
No Longer Available
On a 15 year old car in my case and things like you can't get, that's a bit |
Do you mean the metal pipe in the picture I posted above? If so that’s a turbo pipe. IIRC I had to undo a bolt or two that held the turbo pipes onto the chassis legs, but it’s been a while and I’ve tried to forget the whole experience. I definitely didn’t undo any coolant pipes when I did mine. Recommend wearing safety glasses when you’re grotting around under an old car. If your a glasses wearer, specsavers sell prescription safety glasses. |
