Home > Maintenance & Modifications > What a total
Page 1 of 4 1234>
Axl
2010 Range Rover Sport TDV8 HSE Adriatic Blue
What a total
B@#£%^d of a job trying to do an alternator on a old 09 sport 3.6, I still haven't did it and don't think I will. Can't get the bloody fan off because I can't "hold" the water pump then didn't have a38mm spanner plus can't get the turbo pipe/s off at the alt bolts.
This kind of crap is meant for a garage not some asshole in a drive outside with limited tools.
Post #645766 Sat Dec 14 2024 1:37pm
yeah, its nasty if the fan hasn't been off in a white
leave the belt on.
get the 2 tools. One to hold pulley, and the spanner.
Then give it a sharp knock with a lump hammer
Post #645769 Sat Dec 14 2024 1:42pm
Axl
Can't do that as there's more pipes in front of it, also don't have a 38mil.
I think it'll be sold for spares etc I'm just not in the frame of mind at all to do stuff like this, shouldn't have started it I'm just kidding myself. I honestly think I'm done "working" on cars enough's enough.
Post #645770 Sat Dec 14 2024 1:52pm
JonnyCJ
I reckon £300 at a garage. What do you want for the car ?
I’ll give you £1,000 scrap value as is, spend £300 and then have a car worth £5k.
Your call
Post #645778 Sat Dec 14 2024 8:17pm
Axl
Post #645779 Sat Dec 14 2024 8:42pm
JonnyCJ
I think you’re missing the point. I’m trying to be helpful and saying that you’re not doing yourself a favour by scrapping the car when you can fix it for £300 or so.
There’s plenty of people on here who are trying to help - you just seem to see it as a place to vent your frustrations without actually listening to advice.
My final thoughts are that if you get it to a garage, they can fix it for not a lot in the scheme of things.
Alternatively, scrap it, get £1000 in return and go and buy your Merc back.
Post #645781 Sat Dec 14 2024 8:55pm
Axl
Nobody wants to do it apart from one and they're busy till Feb
The only "advice" I got above was use 2 tools and I already said I didn't have a 38mm.... yes I can buy one but its an fkr of a job hence nobody will do it.
And at over 100 views I think they know too is a b@#£%^d of a job for something like a bloody alternator. Surety they could have put it somewhere easier.
Post #645785 Sat Dec 14 2024 9:27pm
Jabba
Hi, I've been reading a lot lately regarding changing an alternator on a rrs tdv8.
I found the following guide, the guy said that he was told you don't need to remove the fan to get to the tensioner.
Here's the link
https://www.rrsport.co.uk/forum/post527455.html
Hope it helps
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #645793 Sun Dec 15 2024 9:48am
Axl
Thanks for the link yes I've read that before, it's mainly me, I'm just not in the right frame of mind and don't have the right tools.
Post #645794 Sun Dec 15 2024 11:29am
Jabba
Yes, it's does make a big difference. The trouble is the older we get, the more we can't be asked.
I've been restoring a Triumph Stag for the past five years. It's nearly there but I'm spending less time on it. Next year I need to really push myself, get a bit fitter and crack on with all the jobs that need doing. That includes the cars and the house.
All the best
Post #645797 Sun Dec 15 2024 11:57am
gogsy1956
Did mine last year,, maybe I was lucky but the fan came off quite easily, didn't use any special tools,, I know I used a 12" pipe wrench and can't remember what else. Hardest part was getting the 2 bottom bolts back in,, I found that taking off the bottom intercooler hose then pulling the pipe down and tying off gives another 15mm clearance to play with,,, makes a huge difference. It is awkward but a little perseverance will get it sorted. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #645806 Sun Dec 15 2024 7:32pm
Axl
All the best
Craig
Yes I'm finding I can't be bothered doing a lot of stuff now even simple things, I've got to push myself.
It's mainly because now I've no garage to hide in.
Post #645830 Tue Dec 17 2024 12:12pm
Axl
I managed to get the right spanner for it ie 32/36mm and got the fan loosened. This is a love hate with this bloody car.
Yes these bottom bolts were a bad I managed to move the metal and rubber pipe just a smidge out the way, so bad though.
I've still not got it fitted yet though between work and looking after a mother with the start of either dementia or alzheimers hence not in the right frame of mind plus working outside.
Post #645831 Tue Dec 17 2024 12:18pm
JonnyCJ
Hi Axl - hope you had a relaxing Christmas given all that's going on for you.
Did you manage to get any further ?
Jonny
Post #645930 Fri Dec 27 2024 3:23pm
Axl
Hi Jonny
I did thanks, quiet but unusually nice hope you had a good one too.
No still have got this dam alternator on, I know i know.
It's the 2 bolts at the bottom behind the turbo pipes (I'm sure that's where they go). Either that or they're coolant pipes.
I can get it (turbo pipes i think unless it's coolant) loosened at the front, but not the back, no chancei can't get in. I'm on the verge of driving local somewhere and getting the AA out, of course I know what's wrong but let them check it then ask if they fit one. If it came to it I'd say I've got would you guys fit it.
I know the RAC but don't know about them..... just a thought.
Post #645931 Fri Dec 27 2024 4:13pm
Page 1 of 4 1234>
