![]() | Home > Technical > 2014 Range Rover Sport L494 SDV6 - Major Electrical Faults |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 160 ![]() ![]() ![]() |
Driving to work this morning in my L494 and all of a sudden get a 'park brake' not available warning, shortly followed by pretty much every other system fault including, special modes not available, gearbox fault, E-diff fault, Lane departure fault, no speedo and also noticed right hand headlight pack not working.
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 590 ![]() ![]() |
Glad I could be of help |
Just out of interest, did you get new earth studs installed (JLR special insertion tool required) or did you earth them down at another point / another way?
Rivnut and some sealant over the top to protect things |
Hi, thanks for the reply.
m14rsh Member Since: 26 Sep 2010 Location: Norwich Posts: 98 ![]() ![]() |
Just had this exact problem!
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4424 ![]() ![]() ![]() |
3rd post down in this very thread... |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 469 ![]() ![]() ![]() |
227K on the same engine?? If so that’s impressive…. |
Closer to 280k now and running perfectly!
It’s quite reassuring to hear that the engines can do these miles. You don’t hear many good things about these cars, only the bad things. I’ve had my car almost 8 years now and still l enjoy driving it. I hope my car will last long enough to do similar miles. If I continue do my yearly mileage (3k a year) I’d have to keep the car for another 76 years though…It could become a family heirloom……. |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 260 ![]() ![]() |
Just my experience, but the cars I have owned during my high mileage years rarely gave trouble from the engines. Although my current annual mileage is now low, circa 5k, I try to minimise journeys where the engine doesnt get up to temp. Im on 97k and fully expect another 100k out of the engine. Regular oil changes are the key. RRS HSE Dynamic SDV6 2014
I make sure my car gets up to temperature every time I use it. I know that short journeys don’t agree with diesels. I also get the service done yearly irrelevant of the mileage so it gets an oil change as a minimum yearly, every time the MOT is due. I totally agree with the regular oil changes |
