Home > Technical > 2014 Range Rover Sport L494 SDV6 - Major Electrical Faults
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Driving to work this morning in my L494 and all of a sudden get a 'park brake' not available warning, shortly followed by pretty much every other system fault including, special modes not available, gearbox fault, E-diff fault, Lane departure fault, no speedo and also noticed right hand headlight pack not working.
Managed to limp to work and let vehicle shutdown, restarted and all faults are still present. I'm thinking for all systems to go down at once it could be an earthing issue?
Has anyone here had similar and would like to point me in a general direction? Mrs in on way to work bringing my scanner, not sure what that will show though, considering the amount of faults presently!
Just hit 227K fault free miles and now this!!!
Thanks to all in anticipation
Mike
Post #621860 Mon Feb 14 2022 9:13am
Red Arrow
Will be drivers side headlight earth, had the same issue with mine last week on the offside and a couple of years back on the nearside Thumbs Up
Post #621885 Mon Feb 14 2022 5:26pm
2 RRS
Hi
Many thanks for your spot on diagnosis!
Found the offside earth stud completely sheared off, temporary fix by earthing via the accelerometer stud, couple of new studs on order, think I'll do the nearside at the same time to avoid a repeat performance!
I'm not complaining considering my mileage!
Post #621928 Tue Feb 15 2022 9:36am
Red Arrow
Glad I could be of help Thumbs Up
Post #621951 Tue Feb 15 2022 9:24pm
2 RRS
Just out of interest, did you get new earth studs installed (JLR special insertion tool required) or did you earth them down at another point / another way?
Many thanks
Post #621962 Wed Feb 16 2022 12:59pm
Red Arrow
Rivnut and some sealant over the top to protect things Thumbs Up
Post #621971 Wed Feb 16 2022 7:42pm
2 RRS
Hi, thanks for the reply.
I'm going to try the JLR replacement studs as I've fabricated a tool to insert it, failing that I've got a Avdel Gun and inserts, so at least I have a fall back.
Saturday morning job I feel!
Post #621983 Thu Feb 17 2022 12:41pm
