Home > Technical > 2014 Range Rover Sport L494 SDV6 - Major Electrical Faults
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Driving to work this morning in my L494 and all of a sudden get a 'park brake' not available warning, shortly followed by pretty much every other system fault including, special modes not available, gearbox fault, E-diff fault, Lane departure fault, no speedo and also noticed right hand headlight pack not working.
Managed to limp to work and let vehicle shutdown, restarted and all faults are still present. I'm thinking for all systems to go down at once it could be an earthing issue?
Has anyone here had similar and would like to point me in a general direction? Mrs in on way to work bringing my scanner, not sure what that will show though, considering the amount of faults presently!
Just hit 227K fault free miles and now this!!!
Thanks to all in anticipation
Mike
Post #621860 Mon Feb 14 2022 10:13am
Red Arrow
Will be drivers side headlight earth, had the same issue with mine last week on the offside and a couple of years back on the nearside Thumbs Up
Post #621885 Mon Feb 14 2022 6:26pm
2 RRS
Hi
Many thanks for your spot on diagnosis!
Found the offside earth stud completely sheared off, temporary fix by earthing via the accelerometer stud, couple of new studs on order, think I'll do the nearside at the same time to avoid a repeat performance!
I'm not complaining considering my mileage!
Post #621928 Tue Feb 15 2022 10:36am
Red Arrow
Glad I could be of help Thumbs Up
Post #621951 Tue Feb 15 2022 10:24pm
2 RRS
Just out of interest, did you get new earth studs installed (JLR special insertion tool required) or did you earth them down at another point / another way?
Many thanks
Post #621962 Wed Feb 16 2022 1:59pm
Red Arrow
Rivnut and some sealant over the top to protect things Thumbs Up
Post #621971 Wed Feb 16 2022 8:42pm
2 RRS
Hi, thanks for the reply.
I'm going to try the JLR replacement studs as I've fabricated a tool to insert it, failing that I've got a Avdel Gun and inserts, so at least I have a fall back.
Saturday morning job I feel!
Post #621983 Thu Feb 17 2022 1:41pm
m14rsh
Just had this exact problem!
How do I find and access the drivers side headlight earth please? 2014 RRS
Post #645776 Sat Dec 14 2024 7:07pm
Disco_Mikey
3rd post down in this very thread...
Post #645789 Sat Dec 14 2024 11:50pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
227K on the same engine?? If so that’s impressive….
Post #645795 Sun Dec 15 2024 12:41pm
2 RRS
Closer to 280k now and running perfectly!
Must have come out of the factory on a good day!
Post #645796 Sun Dec 15 2024 12:44pm
Johnrrs
It’s quite reassuring to hear that the engines can do these miles. You don’t hear many good things about these cars, only the bad things. I’ve had my car almost 8 years now and still l enjoy driving it. I hope my car will last long enough to do similar miles. If I continue do my yearly mileage (3k a year) I’d have to keep the car for another 76 years though…It could become a family heirloom…….
Post #645798 Sun Dec 15 2024 1:47pm
Grimble
Just my experience, but the cars I have owned during my high mileage years rarely gave trouble from the engines. Although my current annual mileage is now low, circa 5k, I try to minimise journeys where the engine doesnt get up to temp. Im on 97k and fully expect another 100k out of the engine. Regular oil changes are the key. RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #645810 Mon Dec 16 2024 11:28am
Johnrrs
I make sure my car gets up to temperature every time I use it. I know that short journeys don’t agree with diesels. I also get the service done yearly irrelevant of the mileage so it gets an oil change as a minimum yearly, every time the MOT is due. I totally agree with the regular oil changes
Post #645819 Mon Dec 16 2024 9:08pm
