Home > General (L461) > Brake pads worn warning
Padzmac
Hello everyone, I have a MY23 L461 with 26000 miles on the clock and I have just had a brake pads worn warning come up. It initially came on and then went away for a few days, but is now permanently on.
Is 26000 miles too soon for my pads to be worn or is this more likely a sensor failure? I have a normal driving style (I think!) and most of my miles are a weekly 200 round trip commute. I use adaptive cruise control a lot; is this more harsh on the brake pads? I previously had a 2020 Disco Sport with adaptive cruise control and I traded that in with 42000 miles with no pad issues.
Thanks in advance for any advice.
Paddy
Post #645188 Mon Nov 11 2024 1:06pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
There have been reports of brake pads - particularly at the rear needing replacement at less than 10k with lots of use of Adaptive Cruise due to continual feathering of brakes. If you look on the US forum there are loads of threads about it.
Only way to tell is measure pads in the callipers to see if they are worn.
Post #645210 Tue Nov 12 2024 11:31pm
Padzmac
I've spoken to an indie who says it is possible, so I have asked for a quote to compare against the main dealership. I did read some posts on the US site, hence my query about ADC, but was wondering if anyone on this side of the pond had had the same.
Post #645222 Wed Nov 13 2024 7:21pm
ChunkRRS
Scotland
Paddy, 27,000 miles and I have the same message. looks like it's the rear pads that are gone. landrover circa £400, local indy doing them for £350.
On another note how are your tyres looking? I need all 4 replaced as well as the pads
Post #645498 Wed Nov 27 2024 1:31pm
Padzmac
Hi Chunk, had the rear pads replaced today at a main dealer as the price was much the same as the indie. The main dealer also do Blue Light discount which brought it in at £436. Tyres are okay at the moment, thankfully!
Post #645505 Wed Nov 27 2024 6:36pm
nigels888
seems about the right mileage. I have 48k on the clock and am coming up to my second set of front pads. garage says the front wears quicker on these as the front does most of the braking. mind you the price for the pads themselves comes in at about £220
Post #645513 Thu Nov 28 2024 8:33am
ChunkRRS
Scotland
Paddy, you are doing well to get 26k out of the front tyres with no sign of needing to be changed.
nigels888, that's very strange as my front pads are still fine at 27k miles but the rears needed changing.
Post #645517 Thu Nov 28 2024 1:55pm
Rowdie
Just a thought, could it be that one of you is driving a hybrid PHEV and the other is not hence the difference in brake pad wear? Be interested to know
Post #645518 Thu Nov 28 2024 2:04pm
ChunkRRS
Scotland
that would be good to know wouldn't it.
D350 here
Post #645519 Thu Nov 28 2024 2:10pm
nigels888
mines just a normal 70 plate rrs 3l diesel definately not had rears done yet although on the discovery 5 It went through two sets of rear to a set of front
Post #645520 Thu Nov 28 2024 3:15pm
ChunkRRS
Scotland
Ah ok, yours is an L494 with a different braking system so will be different usage compared to the L461. I got to nearly 30k in my 70 plate without needing pads before i traded it in
Post #645532 Fri Nov 29 2024 12:42am
scrumps
I’m on my fifth Sport (see my sig block below).
Most went back at 3yrs/36,000 miles except the last one (post retirement) which went back at 54 months /24,000 miles.
I can ‘t remember when I last bought brake pads!!!!
I used to get 32-36,000mls out of a set of tyres too.
It’ll be interesting to see what happens with this L461 D300.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #645533 Fri Nov 29 2024 11:01am
ChunkRRS
Scotland
Scrumps, funnily enough this is my 4th and the first one I’ve needed brakes for.
Post #645544 Sat Nov 30 2024 10:32am
