![]() | Home > Technical > RRS TDV6 2.7 ISSUES |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 180 ![]() ![]() ![]() |
Maybe worth just checking the in tank low pressure fuel pump is working. You should be able to hear it for about 10 secs after turning the ignition to on. You can also check at the LP schrader valve at rear centre of engine, again switch ignition on and you should get a steady low pressure fuel supply out of the valve. If you change the filter and the LP pump isn't working you'll have fun trying to start it as air will be in the lines. |
Yes, self bleeding. As long as your LP tank pump is working, after changing the filter, cycle the ignition a few times (2-3) and this will then prime the filter and fuel lines. Water in fuel sensor just unscrews from bottom of filter after you've removed it from the filter housing. |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 438 ![]() ![]() ![]() |
What the OP has not told us is this a new purchase with issues or has he been driving it for months with no problems?
Hoverdroid Member Since: 17 Mar 2024 Location: Swindon Posts: 36 ![]() ![]() ![]() |
Agreed i should of given a bit more background |
As for battery its a new one (019)
For the handbrake go to youtube channel "LR Time" he shows a total removal and repair of the electric handbrake system. Always listen to old people or when they die you will live on in ignorance.
LR Time, Christian, his videos have been my saviour (Its where i learned about the oil pumps and oil grades)
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Another silly thing to check is the brake bulbs. Blown brake bulbs can cause the HDC failure message because the HDC is hardwired in to the brake system and brake lights work when it is operating. Blown bulbs will prevent HDC operation.
Gearbox fault will definitely be related to the Mechatronics unit, the vin in your donor gearbox will not match the original stored in the BCM and engine ecu, hence the fault. Many years ago I changed the gearbox in my L320, but carried over the original Mechatronics unit and all was fine, other than needing to do a transfer case clutch re-learn.
Thanks guys for the comments i will look into these.
JLR will have you believe only a new Mechatronic unit can be assigned a VIN and only once, however it can be done, find a friendly person with SDD and perform a replace 'Mechatronic unit routine' and it will overwrite the donor vin. Not sure if GAP IID can do it, if not I'm sure Patrick at Gap could enable it, obviously you'd need a GAP IID tool (not cheap, but well worth it in the long run).
yes it can be done with GAP IDD.
Sadly i dont have a gap IID tool |
Billy82 Member Since: 25 Sep 2024 Location: Bolton Posts: 44 ![]() ![]() ![]() |
Where are you based |
