Home > Maintenance & Modifications > Transmission Fault |
zaphod Member Since: 16 Jan 2015 Location: Liverpool Posts: 290 |
Can anyone suggest what this issue might be please? Every time I park up and turn off the ignition I get a 'Transmission Fault' message appear on the little screen on the dash. The car drives perfectly, no issues selecting gears, park or reverse and other than that message I wouldn't be aware of any issue.
Mon Jun 10 2024 1:37pm |
Heremyjill Member Since: 01 Jun 2020 Location: Shrewsbury Posts: 87 |
I Have found this for you:
Mon Jun 10 2024 1:48pm |
That's a bit of a bizarre thing to do but hey if it helps fix it I'll try turning on my lights when I'm next in the car and see what happens, thanks! |
Mon Jun 10 2024 2:19pm |
Well me, when I put my headlights on the transmission fault doesn't appear! Never in a million years would I have thought would help but there you go!
Mon Jun 10 2024 4:30pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
https://www.disco3.co.uk/forum/good-luck-f...ight=P081c
Mon Jun 10 2024 6:01pm |
That looks kind of scary and pretty involved - will have to be a sunny weekend job!
Tue Jun 11 2024 8:42am |
pelle Member Since: 01 Jan 2014 Location: Sigtuna Posts: 48 |
I have transmission fault on and was finding this thread today.
Wed Sep 11 2024 3:09pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
Yeap.
Wed Sep 11 2024 3:16pm |
In the US-forum someone referred to green/pink wires and you say red wire?
Thu Sep 12 2024 10:43am |
Well if you can find splices for both colours, itās probably worth doing both while you are at it ! |
Thu Sep 12 2024 11:02am |
You are right.
Thu Sep 12 2024 11:12am |
thegolffather Member Since: 07 Jun 2024 Location: Guam Posts: 12 |
What is the lamp switch on trick? on mine the error does not come on until I select drive 1973 Clubman GT * 2013 MB C250 * 2013 BMW X1 * 2013 RRS HSE Luxury * 2016 Mazda MX5 |
Fri Sep 13 2024 1:08am |
If you switch the headlights on before starting the engine you will not have the
Fri Sep 13 2024 8:45am |
Thank you 1973 Clubman GT * 2013 MB C250 * 2013 BMW X1 * 2013 RRS HSE Luxury * 2016 Mazda MX5 |
Mon Sep 16 2024 12:11am |
