![]() | Home > Maintenance & Modifications > Transmission Fault |
zaphod Member Since: 16 Jan 2015 Location: Liverpool Posts: 290 ![]() ![]() ![]() |
Can anyone suggest what this issue might be please? Every time I park up and turn off the ignition I get a 'Transmission Fault' message appear on the little screen on the dash. The car drives perfectly, no issues selecting gears, park or reverse and other than that message I wouldn't be aware of any issue.
Heremyjill Member Since: 01 Jun 2020 Location: Shrewsbury Posts: 91 ![]() ![]() ![]() |
I Have found this for you:
That's a bit of a bizarre thing to do but hey if it helps fix it I'll try turning on my lights when I'm next in the car and see what happens, thanks! |
Well |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
https://www.disco3.co.uk/forum/good-luck-f...ight=P081c
That looks kind of scary and pretty involved - will have to be a sunny weekend job!
pelle Member Since: 01 Jan 2014 Location: Sigtuna Posts: 48 ![]() ![]() |
I have transmission fault on and was finding this thread today.
Yeap.
In the US-forum someone referred to green/pink wires and you say red wire?
Well if you can find splices for both colours, itās probably worth doing both while you are at it ! |
You are right.
thegolffather Member Since: 07 Jun 2024 Location: Guam Posts: 13 ![]() ![]() ![]() |
What is the lamp switch on trick? on mine the error does not come on until I select drive 1973 Clubman GT * 2013 MB C250 * 2013 BMW X1 * 2013 RRS HSE Luxury * 2016 Mazda MX5 |
If you switch the headlights on before starting the engine you will not have the
Thank you 1973 Clubman GT * 2013 MB C250 * 2013 BMW X1 * 2013 RRS HSE Luxury * 2016 Mazda MX5 |
