![]() | Home > General > Charging P400e |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1856 ![]() ![]() |
The basic charger works fine, do you have a cheap overnight tariff such as Octopus?
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 919 ![]() ![]() |
jimbg
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 284 ![]() ![]() ![]() |
We got a HyperVolt charger and it has been faultless. Only about £650 installed iirc |
JDPRRSUK
Workpermit Member Since: 23 Jun 2024 Location: Surrey Posts: 32 ![]() ![]() |
I've been considering the same, but my garage is a fair distance from the main fusebox (separate from the house), so with the cabling work involved, not worth it. You can only benefit from off-peak savings if you have a fast charger installed and the sums just don't add up for my usage.
Another question, I take it there is a separate battery for the internal combustion engine (or not??) & if the car is sitting for a while you can connect a Ctek to this battery to keep it charged up or does the plug in charger also feed this battery. Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e |
I believe there is a smaller than normal 12 volt battery to drive the instruments, lights, etc. 2023 P440e SE Dynamic on order -cancelled
The plug in charger feeds the main battery and that charges the 12v battery. No need for a CTEK on that if you are regularly charging the car. |
JDPRRSUK
