Home > General > Charging P400e
Lindab
Charging P400e
Thinking of getting a P400e but was wondering if the 3 pin charger is fine or should I splash out & get a wall charger. Mileage will not be a lot, so don't really need a fast charge. Thoughts or problems please Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #643726 Tue Aug 13 2024 3:23pm
jimbg
The basic charger works fine, do you have a cheap overnight tariff such as Octopus?
You probably will not be able to fully charge during the cheap window with a slow charger though.
However a wall charger is not cheap! 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #643729 Tue Aug 13 2024 4:51pm
Lindab
jimbg
Thanks for that. No cheap overnight tariff Big Cry Looks like around £1100 for a wall charger after a quick google. Get a few 3 pin charges for £1100 Thumbs Up Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #643731 Tue Aug 13 2024 6:17pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
We got a HyperVolt charger and it has been faultless. Only about £650 installed iirc
Post #643738 Tue Aug 13 2024 9:36pm
Lindab
JDPRRSUK
Thanks for that. I shall have a look at them. Far more sensible price Thumbs Up Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #643741 Wed Aug 14 2024 7:14am
Workpermit
I've been considering the same, but my garage is a fair distance from the main fusebox (separate from the house), so with the cabling work involved, not worth it. You can only benefit from off-peak savings if you have a fast charger installed and the sums just don't add up for my usage.
Different gravy if I had a full EV of course, as I'd be entirely reliant upon it. 2024 RRS L461 P460e AB
Post #643753 Wed Aug 14 2024 9:48pm
Lindab
Another question, I take it there is a separate battery for the internal combustion engine (or not??) & if the car is sitting for a while you can connect a Ctek to this battery to keep it charged up or does the plug in charger also feed this battery. Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #643771 Fri Aug 16 2024 9:29am
jimbg
I believe there is a smaller than normal 12 volt battery to drive the instruments, lights, etc. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #643779 Fri Aug 16 2024 10:37am
JDPRRSUK
The plug in charger feeds the main battery and that charges the 12v battery. No need for a CTEK on that if you are regularly charging the car.
Post #643788 Fri Aug 16 2024 9:47pm
Lindab
JDPRRSUK
Thanks for that, it's a lot clearer now. Like to know as much as possible about these leccy things before flicking the switch Rolling with laughter Censored
Any other info, pitfalls Big Cry or good things Thumbs Up would be appreciated Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #643792 Sat Aug 17 2024 8:04am
