Home > General > Charging P400e |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1849 |
The basic charger works fine, do you have a cheap overnight tariff such as Octopus?
Tue Aug 13 2024 4:51pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 913 |
jimbg
Tue Aug 13 2024 6:17pm |
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 275 |
We got a HyperVolt charger and it has been faultless. Only about £650 installed iirc |
Tue Aug 13 2024 9:36pm |
JDPRRSUK
Wed Aug 14 2024 7:14am |
Workpermit Member Since: 23 Jun 2024 Location: Surrey Posts: 32 |
I've been considering the same, but my garage is a fair distance from the main fusebox (separate from the house), so with the cabling work involved, not worth it. You can only benefit from off-peak savings if you have a fast charger installed and the sums just don't add up for my usage.
Wed Aug 14 2024 9:48pm |
Another question, I take it there is a separate battery for the internal combustion engine (or not??) & if the car is sitting for a while you can connect a Ctek to this battery to keep it charged up or does the plug in charger also feed this battery. Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e |
Fri Aug 16 2024 9:29am |
I believe there is a smaller than normal 12 volt battery to drive the instruments, lights, etc. 2023 P440e SE Dynamic on order -cancelled
Fri Aug 16 2024 10:37am |
The plug in charger feeds the main battery and that charges the 12v battery. No need for a CTEK on that if you are regularly charging the car. |
Fri Aug 16 2024 9:47pm |
JDPRRSUK
Sat Aug 17 2024 8:04am |
