Home > General > Welcome to RRSPORT.CO.UK - say hello here! |
Sputty37 Member Since: 27 Nov 2023 Location: Suffolk Posts: 15 |
Love it |
Mon Dec 18 2023 4:00am |
Why ya not sure? Unexpected problems already?
Tue Dec 19 2023 12:23pm |
Toby and MoneyPit Member Since: 19 Dec 2023 Location: Warwickshire Posts: 2 |
CO emissions
Thu Dec 28 2023 11:50am |
Ian_D Member Since: 29 Dec 2023 Location: Barnsley Posts: 4 |
Hi All,
Fri Dec 29 2023 5:41pm |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 457 |
Welcome to the forum. why is it not drivable ? |
Fri Dec 29 2023 5:54pm |
Sorry I forgot to put the reason!... Coolant leak.
Fri Dec 29 2023 6:17pm |
Good luck, you seem to know what you are doing. Keep us updated .👍 |
Fri Dec 29 2023 6:28pm |
Hope it is an easy fix. Defo sounds like ya know ya stuff, so sure you’ll be fine. Probably was a bargain price giving the issues too, so happy days 😊 |
Fri Dec 29 2023 6:57pm |
Cheers guys will give you an update tomorrow!
Sat Dec 30 2023 12:16am |
MortenB Member Since: 30 Dec 2023 Location: Kapp Posts: 1 |
Hi there
Sat Dec 30 2023 2:40pm |
Eddie_173 Member Since: 13 Jan 2024 Location: Essex Posts: 4 |
Glad to be a member of this forum. |
Sat Jan 13 2024 8:10pm |
amx56 Member Since: 14 Jan 2024 Location: Lancs Posts: 1 |
Hello
Sun Jan 14 2024 8:55pm |
Good choice, same as mine. Any photos?? |
Sun Jan 14 2024 10:02pm |
Bit of a late update! Got car home on trailer all ok. (was only 9.9 miles!) It was the coolant bridge pipe that had failed like I thought - Fixed that now, had it running for 20 mins on the drive and all seems fine. Took it for a quick test run up the lane and back half a dozen times and all seems fine Then had random issues with the boot not opening, which then became 'every time'... long story short, with the glass section open I had to pull back the lower plastic trim, cut the wires to the boot locking motor and manually apply power! Since then I removed the lock and cleaned everything up / oiled etc... its been fine since. Yesterday I replaced the cambelt as there was no history of it ever been done. Bloody glad I did as although it looked in really good condition, the date stamp on it was 2 months before the car was registered (so its obviously the original belt at 126k / 13.5 years ) Now just got to do oil / filter change. And fix the passenger side front door motor. Getting there bit by bit... |
Mon Jan 15 2024 9:47am |
