Home > General > Welcome to RRSPORT.CO.UK - say hello here!
Page 383 of 385 <123 ... 382 383384385>
Steveiboy
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Hello
Hi i am new to the group but not new to Range Rovers.I have recently brought a RRS TDV6 2012 but are having a few issues i keep getting a warning come up Restricted Performance.I have been advised it could be s split hose is this a easy job to do and are there any videos on how to do this thanks in advance for any help or advice given.
Post #644916 Sat Oct 26 2024 5:07pm
Spridget
Hi All
I've sneaked in through the back door because I don't have a RRS. I do however (for my sins) run a L405 which is a close relative.
I saw a couple of interesting posts on this site and thought I would join in.
Cheers.
Post #645017 Fri Nov 01 2024 9:38am
benypl
Poland
New member
Hi. Im Ben. Im auto electrician. Dont have RRS but repairing one. Cheers
Post #645101 Mon Nov 04 2024 6:44pm
Pagey
Hi
Currently have a 2011 RRS 3.0TDV6 OverFinch
Looking forward to gaining everyone's experience 😀
Post #645149 Fri Nov 08 2024 10:08pm
Axl
2010 Range Rover Sport TDV8 HSE Adriatic Blue
Another new kid
On the block so to speak with an 09 sport tdv8.
Post #645339 Wed Nov 20 2024 1:35am
Majistrat
Canada 2010 Range Rover Sport Supercharged Baltic Blue
Hello ,
Majistrat is the name here im a proud owner of RRS for 5 years now. Enjoying it like no one ever.
Post #645865 Thu Dec 19 2024 2:35pm
OZBOB
Australia
Hi all.
OzBob here.
Owner of RRS.
Looking at improving looks on the cheap..
Have some original Kahn rims.
Looking for tips and or parts to face lift the ol gal..
Any ideas welcome pics also mines in white with a little sunfade on bonnet clear coat so cover that would be good also..
TI A..
Appreciate you all safe driving and A Very Merry Christmas.
Post #645888 Sun Dec 22 2024 1:09pm
OZBOB
Australia
Hi all.
OzBob here.
Owner of RRS.
TI A..
Post #645889 Sun Dec 22 2024 1:09pm
loulou
France
bonjour , je me présente je suis loulou nouveau ,je viens d'aguerri un RRS TDV6 2006 430000 KM , j'ai hâte de savoir l'expérience de tout le monde .
Post #645966 Sun Dec 29 2024 5:38pm
Spera
New member
Hi, joined today as I’m looking for information on the 2014 onwards RRS model to aid my purchase. Usually had Alfa Romeo’s and BMWs but fancy a change. Thankyou.
Post #646024 Tue Dec 31 2024 10:16pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Welcome, what info you after? I’ve had my 2015 but MY16 now for almost 8 years and still loving it. Ask away….
Post #646026 Tue Dec 31 2024 11:03pm
Rich A
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Alaska White
Hello
I have a RRS L320 Autobiography and love it to bits
I’ve had it about 18 months now, but have had to stand her for about four months due to surgery, have had to take battery off to recharge, when I reconnected the radio is now upside down and back to front?
I’ve tried disconnecting the negative on the battery for 20 minutes for a hard reset but it hasn’t worked, any ideas?
Best regards
Post #646035 Wed Jan 01 2025 4:07pm
Roy3112
Thank you
Thank you, Yes I have joined as Like the look of the RR Sport and want to learn about ownership before I buy one. Probably spend around £16k and don`t want to put my hand in a bag of snakes
Post #646192 Thu Jan 09 2025 5:10pm
DuncThe Geek
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Zermatt Silver
Hello there!
SEO Web Marketing Geek, writer, photographer & electron juggler from the wilds of Merseyside here.
Just got my L320, rather like it. A change from my V70 that someone reversed into, writing it off Censored
Working my way through it. Previous owner wasn't too savvy about changing bulbs. Both numberplate lights had blown and they'd obviously previously pinched the luggage space light bulb to get it going (I notice a past MOT has a failed numberplate light on it Laughing )
The rear wiper was loose on the spindle, a nice easy fix for once. Slow puncture fixed, missing dust caps replaced and I finally managed to get the service menu to display the oil level - had to Google that one!
No fault codes but it does have the yellow triangle & adaptive dynamics fault showing so I'm hoping it's the wiring as that seems pretty common - one to check in daylight!
So here I am, get used to the daft questions that are bound to follow!
Post #646195 Thu Jan 09 2025 10:35pm
Martian999
After several weeks of searching I finally made the decision to 'return to the fold' by acquiring my fourth Range Rover vehicle.
Despite owning a progression of RR variants, (starting with a rather dilapidated P38, followed by a 2007 FFRR and then a 2010 RRS TDV8 3.5 Autobiography), it would appear that I still haven't learned my lesson as I now have a rather smart looking L494 RRS SDV8 4.4 Autobiography sitting on my drive.
It appears to be in excellent condition, (inside and outside), and everything appears to be working too other than the lack of 12v at the two 12v power sockets, (both located in between the front seats - one in the cupboard holder compartment and the other in the cubby with the 'fridge' and the various audio and USB sockets).
A quick check of the owner handbook gave me the fuse number, (possibly fuse 52 in the glove compartment fuse box), and, sure enough, the fuse was blown.
That was the simple bit as I was shocked, (no pun intended), to note that the fuse box is accessed via a small aperture cut in the steel plate behind the glove compartment and the actual fuse box was located a further 8 inches towards the firewall!
Therefore access is quite limited and, (once you insert your hand through the access hole), you can't see what you are doing and have to rely on a combination of memory and touch!
I managed to extract the blown fuse, (and then insert a new one), without dropping it down into the abyss!
I chose to use a pair of forceps to hold the fuse when extracting it, (more secure than the plastic tweezer that sits patiently in its parking bay waiting to be used), but I found it easier to hold the new fuse in my fingers when inserting it back into its socket.
I am hoping that will be all that I will have to do to the vehicle, (for a few days at least), and I have yet to plug my iCarsoft Scanner in just to see what, (if any), errors are logged in the various systems.
Fingers crossed!
Post #646291 Tue Jan 14 2025 12:08am
