Home > General (L461) > Trickle Charging
RR Ally
Trickle Charging
I have a P510e MY 23 and want to keep the 12v battery trickle charged when I am away.
Firstly, is this a good idea to trickle charge this lithium battery ?
Secondly, looking for a charger most of them say they are only suitable for batteries with a BMS (battery management system). Does the RRS have a BMS on the 12v battery 2022 P510e RRS AB Frenze Red
2021 BMW i3
Post #638310 Sun Dec 24 2023 11:58am
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
I have the older RRS and put mine on trickle charge when I know it won’t be used for more than 2 weeks (which is quite often) Mine doesn’t have the Lithium battery but my motorbike does and that’s on trickle charge all the time. You must make sure that you get a Lithium battery charger to charge a lithium battery. Do not use a normal battery charger. All modern batteries have BMS built in now I believe
Post #638312 Sun Dec 24 2023 12:55pm
scrumps
The Land Rover charger is a branded version of a CTEK charger.
I have the 12v version but also need a charger for 6v on our WW2 jeeps so one of these was recommended by my battery shop. It senses the type of battery and shows the state of charge for both 6 & 12 v too.
https://www.tayna.co.uk/battery-chargers/a...25cf2a61ba
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #638314 Sun Dec 24 2023 1:27pm
MikeJG
Does a PHEV even have a 12v battery? L461 P460e AB
Post #638320 Sun Dec 24 2023 9:22pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
I have used a CTEK for years but saw that my new D350 RRS comes with a lithium battery that needs a different kind of maintainer. Bought the CTEK Lithium XS (looks pretty much same as NXS but case is bluish).
And yes pretty sure the PHEV has a 12V too.
Post #638321 Mon Dec 25 2023 12:32am
JDPRRSUK
*MXS 5. (Is there a way to edit posts on here?)
Post #638322 Mon Dec 25 2023 12:37am
Yes, there's an edit button. Thumbs Up
Edit: It's down at the right hand bottom corner of your post where the the "reply"/"quote" button is. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #638324 Mon Dec 25 2023 11:13am
JDPRRSUK
I think I must be missing something because I can’t find any way… do you use an app for the forum or just through a browser?
Post #638325 Mon Dec 25 2023 12:11pm
scrumps
JP,
As RRSTDV8 says, once you’re logged in to the forum, the “edit” button should appear on the lower blue bar, just inwards from the ‘quote” button.
It will only appear on comments you have written within a thread.
App or browser is immaterial.
Post #638331 Mon Dec 25 2023 9:46pm
This is on a PC browser but it's similar on a phone browser. 2012 SDV6 - it's missing a couple of cylinders
Post #638333 Mon Dec 25 2023 10:35pm
JDPRRSUK
I don’t see that image on my phone … looks like this:
Post #638336 Tue Dec 26 2023 12:33am
JDPRRSUK
And there is no link to quote or edit 🤔
Post #638337 Tue Dec 26 2023 12:33am
JDPRRSUK
Think I have worked it out.. I have been on the ‘mobile site’ which doesn’t seem to have those options but you can log into desktop site on a phone through browser which does..
Thanks for your help…
Post #638338 Tue Dec 26 2023 12:37am
RR Ally
Thanks everyone , I now have a lithium 1amp trickle charger and it works just fine. 2022 P510e RRS AB Frenze Red
2021 BMW i3
Post #638377 Thu Dec 28 2023 11:08am
Atlanticjon
Northern Ireland
Does the L461 have a external charge socket or is it a cigarette socket internally
Thanks
Post #639670 Wed Feb 14 2024 8:47pm
