![]() | Home > General (L461) > Trickle Charging |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 474 ![]() ![]() ![]() |
I have the older RRS and put mine on trickle charge when I know it won’t be used for more than 2 weeks (which is quite often) Mine doesn’t have the Lithium battery but my motorbike does and that’s on trickle charge all the time. You must make sure that you get a Lithium battery charger to charge a lithium battery. Do not use a normal battery charger. All modern batteries have BMS built in now I believe |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 553 ![]() ![]() |
MikeJG Member Since: 30 Aug 2022 Location: Shropshire Posts: 65 ![]() ![]() |
Does a PHEV even have a 12v battery? L461 P460e AB |
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 293 ![]() ![]() ![]() |
I have used a CTEK for years but saw that my new D350 RRS comes with a lithium battery that needs a different kind of maintainer. Bought the CTEK Lithium XS (looks pretty much same as NXS but case is bluish).
*MXS 5. (Is there a way to edit posts on here?) |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
Yes, there's an edit button. |
I think I must be missing something because I can’t find any way… do you use an app for the forum or just through a browser? |
JP,
This is on a PC browser but it's similar on a phone browser. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
I don’t see that image on my phone … looks like this:
And there is no link to quote or edit 🤔 |
Think I have worked it out.. I have been on the ‘mobile site’ which doesn’t seem to have those options but you can log into desktop site on a phone through browser which does..
RR Ally Member Since: 28 Nov 2015 Location: Kings Lynn Posts: 65 ![]() ![]() |
Thanks everyone , I now have a lithium 1amp trickle charger and it works just fine. 2022 P510e RRS AB Frenze Red
Atlanticjon Member Since: 22 Apr 2015 Location: Coleraine Posts: 42 ![]() ![]() |
Does the L461 have a external charge socket or is it a cigarette socket internally
