![]() | Home > Technical > RRS 2006 - loud metal banging when braking - missing bolt |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
Before someone tells you there's no picture.
RRSportTDV6BNEAU Member Since: 28 Jun 2023 Location: QLD Posts: 3 ![]() |
thanks Col, (and thanks for sharing the image!)
The caliper bracket (X) should be bolted to stub (Y) solid with the missing bolt, the caliper itself should move on the guide/slider pins, which is where the rubber boot appears to have come from by the look of it, although a bigger picture showing more might help.
thanks very much for the info Col. really appreciate it. |
NoExpert Member Since: 28 Jan 2022 Location: PoznaĆ, Poland Posts: 493 ![]() ![]() ![]() |
Those bolts take 275 nm of torque, somebody really screwed up big if one went missing and the other is loose. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
