![]() | Home > Tips & Tricks > How to replace the front seat base foam |
The foam pad is the same in the a/b don't see any reason the heating element would be different.
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 225 ![]() ![]() ![]() |
Ah ok, perhaps I needed to order LR016246 instead then ?
Just looked at L/R microcat parts list says LR016245 is for Taurus Leather/PVC what ever that looks like and LR016246 is for Windsor Leather/Alacantra.
Ah ok, my fault, thanks Col
That's just typical, the heating element I need, LR016246, is currently out of stock and is on back order |
Can you not try and gently peel the old one of the foam and use some spray on adhesive to stick it on the new foam, assuming the heater was still working of course, might be worth a try.
Hi Col,
Lesson learnt there for the future Craig, make sure you have the right part's before you start anything. |
Yes definitely, it's strange, I normally do check, christ I've worked on enough cars over the years, oh well |
Right, that's that job done. Picked up the correct element from the dealer at 8 this morning and its all back in. Must admit the new foam does feel alot better.
RRR Member Since: 23 Jan 2024 Location: Banstead Posts: 2 ![]() ![]() ![]() |
Hi knwatkins, appreciate this is a very old post! I have the same seats in mine, can you recall the part number for the foam base? Was it HGB500050? Cheers! |
No HGB500050 is for pre-facelift and facelift SE's, you need LR021399 for HSE/AB facelift variants or that is what is the one I used.
Thank you for the reply, much appreciated. |
