![]() | Home > Tips & Tricks > How to replace the front seat base foam |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5043 ![]() ![]() ![]() |
When I replaced the foam seat pad I used the LR021399 the 500050 is for the pre-facelift or the later SE's. The only other thing you might need is the heated seat element LR016246 but try and salvage your old one as they have become very expensive now, compared with what they used to be.
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 225 ![]() ![]() ![]() |
Thanks JonnyCJ and Col, its just seems strange that a couple of sites show the LR021399 as 4 foam pads and not a seat base pad, weird.
If you are referring to the parts illustration you posted where it shows valance-seat cushion, that is for the pieces of plastic trim that goes to the side and front of the cushion squab.
Thanks Col, so I'm guessing that Britcar just used the wrong illustration
There is nothing wrong with the illustration it is showing all the parts for the seat, it is only showing two seat cushion foam pads for uk spec. cars and the Vin No. at which they changed.
Sorry Col, I mean this picture from Britcar, the one you are relating to is from JLR Classic Parts
Hi folks, stupid question time, do I need to disconnect the battery prior to removing the base due to the airbags at all. I know the base hasn't got any installed.
In a word, No
Thanks Col, thought I'd check before starting
AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 125 ![]() ![]() ![]() |
I can confirm you don’t need to disconnect the battery.
I actually replace those stupid torx screws with flange headed bolts and heavy duty washers when I did mine, as they appear to be made of cheese did the passengers side at the same time as a precaution if it ever needed to be removed.
Thanks guys.
I actually used LR016246 not sure if that is the difference or you have the wrong item in the right packet.
