![]() | Home > Maintenance & Modifications > Suspension Midule |
TommyM Member Since: 02 Nov 2022 Location: Belfast Posts: 19 ![]() ![]() ![]() |
Can someone tell me where suspension control module is found on 2007 rrs 3.6 tdv8 hse please |
Is the range rover sport the same Karlos |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
range rover sport is a Discovery 3 on steroids lol |
Thanxs m8 I only know its l320, didn't know it was same chassis etc |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
The air suspension module is up on the base of the A-pillar behind the dashboard. You can access it by dropping the panel below the steering wheel and then reach up above the pedals. It's a bit tight but you can get to it. 2012 SDV6 - it's missing a couple of cylinders
Thank you, will get round to it soon as height sensors changed, having to wait for parts, even from main dealers here in Belfast |
Are you thinking of changing the module? Why? If you do, you need to set it up as it contains different settings for the heavier TDV8 to the other versions. 2012 SDV6 - it's missing a couple of cylinders
Am changing height sensors but another forum suggested it could be module, I know I would have to get it recoded if it does need changing |
whats up with it? |
Sometimes front os or ns goes into extended mode for no apparent reason, have noticed only when really wet here, so think height sensor sticking or possibly sticky valve block am working through things |
rayodunne Member Since: 17 May 2018 Location: Sudbury Posts: 41 ![]() ![]() ![]() |
Your air suspension system is full of the desiccant from the compressor dryer. The compressor exhaust valve is sticking due to this contamination. When the vehicle tries to lower the air can't leave the system and the system goes to extended due to thinking its hung-up on something. 2009 Range Rover Sport Supercharged |
Do I need to replace anything, or can good mechanic clean it, have problem with hands so would not be able to do it, would this cause amber suspension light with normal height only or is that another issue m8 |
